Wont start on cold mornings - Defender Source
Old May 15th, 2013, 07:32 PM
JTull's Avatar
JTull
Ian Anderson
1985 110 RHD V8 "Buster"
My '85 110 V8 developed a starting problem this winter. On cold mornings the starter motor will turn over but the engine just wont catch and the battery eventually runs out before the engine will start. Try it again in the warm afternoon and it fires right up.
Battery holds a charge at about 12.5V after sitting over night.
Do you think the starter motor is failing or the battery? Or both? Any way to tell?
Cheers
Ian
Old May 15th, 2013, 08:14 PM
Battery should be loaded test.
Connections cleaned,
Plug gaping checked.
EFI or points?
Carb or EFI?
Old May 15th, 2013, 08:16 PM
My first guess would be the choke.
Old May 15th, 2013, 09:20 PM
JTull's Avatar
JTull
Ian Anderson
EFI or points?
Carb or EFI?
'85 so it's twin carbs. Plugs are new (and gapped), new leads, rotor, cap, coil, alternator.Connections clean.
------ Follow up post added May 15th, 2013 09:21 PM ------
What about the choke? Worked fine last year and seems to work exaclty the same as it used to do when the trucks warm.
Old October 27th, 2014, 12:02 PM
JTull's Avatar
JTull
Ian Anderson
New battery and alternator fixed this. Starts like a champ these days.
start
No start in cold cgalpin Series Technical Discussions 2 January 22nd, 2013 07:53 PM
D90 cold start problems aquamanaquaman Defender Technical Discussions 3 November 25th, 2012 05:03 PM
Rough Idle @ Cold Start Grover Defender Technical Discussions 7 May 23rd, 2008 08:24 PM
Cold start problem flippedrover Defender Technical Discussions 3 February 13th, 2008 06:52 PM
