Won't start hot?? - Defender Source
Old June 9th, 2011, 07:53 PM
bar11's Avatar
bar11
rob grentz
1994 defender 90
Won't start hot??
As posted my 94 d-90 won't start when it gets hot I can hear the starter turning slowly but it won't engage but if I wait a while or pour water on it to cool it off it starts right up (or bump start it) do I need a new starter yes the heat shield is on....?? thanks
Old June 10th, 2011, 08:40 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Check the wiring first. Make sure the cables to the starter from the battery are in good shape, and the terminals at both ends are clean and tight.
Tony
1984 110 "Smokey" (sold)
Old June 10th, 2011, 01:29 PM
bar11's Avatar
bar11
rob grentz
1994 defender 90
done
Clean and tightened CHECK still same problem when hot I can hear the starter turning but it is not turning the motor or engaging I tried hitting the selenoid also but when it cools down it works is there a special way the heat sheild is suppose to be I know it's there and looks straight and all but???
Old June 10th, 2011, 01:32 PM
TS888's Avatar
TS888
Tony Sims
1984 110
Sounds like the starter is failing. Everything has a service life.
Tony
Old June 10th, 2011, 01:38 PM
bar11's Avatar
bar11
rob grentz
1994 defender 90
I thought that might be the case Thanks for the suggestions off the spend some $$$$ chachacha ching I was going to do the job myself but are the bolts a pain in the ass to remove and replace question being is it worth paying someone to do the job?
Old June 10th, 2011, 01:56 PM
I replaced mine with a brand new blingy Magnetti Marelli unit a few months ago for under $100 because it was sitting on a forum member's shelf...it's awesome. It is a job you can do yourself as long as you are strong (all were easy except the top bolt which was pretty stuck on mine...luckily Dan had smaller hands and a breaker bar to get more torque on it than I could!). You'll want a 6-12" extension for your socket.
Old June 10th, 2011, 02:01 PM
I think this was the trouble one. I can't remember. Note heat shield location as well.
Old June 10th, 2011, 02:31 PM
Rugbier's Avatar
Rugbier
Gustavo
Josh,
Is this your BS attempt to tell us you are a strong man?
LMAO
NO SIGNATURE
Old June 10th, 2011, 02:44 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Originally Posted by Rugbier View Post
Josh,
LMAO
He had to call me up with my huge muscles to get that SUPER heavy starter out. Just got out of my hernia surgery the other day.
------ Follow up post added June 10th, 2011 02:51 PM ------
It is simple to do. you need an 8mm hex for the bolts (don't know why LR put the one and only hex bolt in there to get filled with mud?). The bottom is easy to get, the top can be tricky. I usually unplug the two spark plug leads in the middle passenger side and stick my hand through there and put the hex and 6" extension on the bolt. then climb under the tuck and hook the ratchet to it and undo it that way.
put the new one in. get the bottom bolt started and somewhat snug, then come in from the top again with bolt hanging on hex and slip it into the hole. climb under and ratchet it tight. then tighten the bottom. hook up all your wires.
Old June 10th, 2011, 03:07 PM
Dan ... I heard you put ballast in your mouse to build up strength for changing starters ... ;-)
Old June 10th, 2011, 06:57 PM
bar11's Avatar
bar11
rob grentz
1994 defender 90
Thanks for all the info folks I ordered 1 today and I'm gonna start eating my wheeties so I'll be good and STRONG but if i need some extra muscles I'll letcha know
Old June 10th, 2011, 07:50 PM
CDeWan
Clay DeWan
5.3L beastie
on a side note if your heat shield takes a crap, I bought one of those flexible heat shield in the form of a heat shield blanket and wrapped the starter in it. I think it was a lot cheaper than a new heat shield.
------ Follow up post added June 10th, 2011 07:52 PM ------
O... and the blanket was heavy too so I had to take my creatine and protein powder months in advance.
start
Defender 90 (97) wont start when motor hot? wolfgang Defender Technical Discussions 24 March 30th, 2011 05:16 PM
Truck will not START ? Weldon Defender Technical Discussions 28 December 15th, 2005 12:58 PM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
