Won't start after short trips - Defender Source
Old April 4th, 2009, 01:34 PM
61rover's Avatar
61rover
John Crouse
My 110 has left me stranded on two errands in the last day. It has been running great and I drove to the mountains to ski last weekend with no problems.
It starts from cold no problem. I drove 5 minutes then ran into a store. When I came out, it would not start. I left it for a few hours then returned and it started right up. I went to pick up food last night and it did it again. Left it there for an hour and then it started.
One clue is that is seems to be idling high them goes to normal at times. TPS? Idle air control valve?
Help is apprciated. I'm afraid to drive it anywhere.
Old April 4th, 2009, 02:37 PM
rogersta's Avatar
rogersta
Drew Rogers
1993 NAS D110 #51
Have you had any work on the tranny recently? I had a similiar prob after having some work done on my 94 D90.
Do, or do not, there is no try!
Old April 4th, 2009, 02:42 PM
61rover's Avatar
61rover
John Crouse
Starting problem
No. I changed the plugs (Champion Copper Plus) and the Distributor cap (genuine) last week though.
Old April 4th, 2009, 04:23 PM
rogersta's Avatar
rogersta
Drew Rogers
1993 NAS D110 #51
Check your ground wire and make sure it is connected at both ends. That was the source of my prob.
Old April 4th, 2009, 08:55 PM
61rover's Avatar
61rover
John Crouse
Starting Problem
It's still doing it. Here's a clue though. If I pull the injector wire from the coil it will start. What do you guys think?
Old April 4th, 2009, 09:08 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
leaking injector, flooding the engine after shutdown?
If you didn't add the last post, I would have said starter solenoid problem like Chevy's with headers tend to get.
My oil line fix
My 100k stopped odometer fix
Old April 4th, 2009, 10:07 PM
61rover's Avatar
61rover
John Crouse
Starting Problem
Thanks Hans. I was thinking about replacing them anyway.
What if the TPS was bad and misreading throttle position at startup?
Old April 5th, 2009, 07:49 AM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
It cold also be an ignition amplifier going bad. My amplifier started failing after driving it (warms up) short distances and initially was intermittent. If your amplifier is still mounted to the side of distributor, you might want to get the kit that relocate it to the left inner fender
start, trip
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
Electrical short with my radio ? paulb Defender Technical Discussions 4 August 11th, 2004 12:25 PM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
