Won't start - Defender Source
Old October 5th, 2016, 06:20 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Won't start
Pulled over for gas just outside of Truckee, filled up and now won't start.
Lots of crank, opened gas line past filter-gas flowing, so assuming spark?
Puffs of white when step on accelerator while cranking. Had head gasket replaced yesterday.
Open for suggestions
Old October 5th, 2016, 06:34 PM
Spark is the easiest thing to test for unless you are by yourself. Is there spark?
White puffs tells me you may still have a head gasket problem. Where is your coolant level?
Old October 5th, 2016, 07:11 PM
Pull the main plug wire off the bottom of the coil, ground to the block as you turn over and see if there's spark there. Then work your way either forward or backwards.
Just had a similar scenario at MAR, culprits were coil, ignition amp module, and cap or rotor. Really didn't suspect cap or rotor since replaced with genuine <1000 miles ago. However....turned out to be the rotor, it developed a hairline crack in it which sends the spark right down the distributor shaft. Luckily, rlynch356 had a trail spare and we popped a new one on and back in business...
Old October 5th, 2016, 09:37 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Running
Cracked fuel line and cranked quickly. ReTightened and got it to start as I pushed accelerator while cranking. Made to hotel Reno.
See if it starts and what adventures await tommorrow. Hope to make it to Great Basin and leave.
Thanks for suggestions!
Old October 5th, 2016, 09:40 PM
.turned out to be the rotor, it developed a hairline crack in it which sends the spark right down the distributor shaft..
Told ya
Worldwide Land Rover Shipment and Importation Service
Bespoke Restoration & Modification work
Old October 5th, 2016, 10:27 PM
yeah, seem like all the rotor buttons you can get now are crap.. so replace often and carry spares
95' D90 - daily driver..
Old October 5th, 2016, 10:42 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Im down in Reno if you need tools/help
PM me
Old October 9th, 2016, 03:41 PM
Squaretyre's Avatar
Squaretyre
Landan
94 d90
Update
Made it to GBR on Friday. Those guys are great, dropped everything to help. Miraculously the truck started right up several times never once staggering. They did find a fault with a coolant sensor.
Drove immediately to gas station, 5 min away tops, and spent nearly 2 hrs there to get it to start.
Gotta love these things
I'll pull each sensor individually try then report back on findings.
Old October 10th, 2016, 01:12 AM
Does it fire and stumble or just complete no start at all?
Completely dead no start sounds like a white wire issue. Get one of those tracer light probes, connect one side to ground and the other to the top side of the chicklet. You should see the light flash as you crank, if you don't the Ecu won't turn on the fuel pump relay for the second time to run the engine.
Old October 10th, 2016, 07:13 AM
Davis's Avatar
Davis
Chris Davis
94 D90, 88 RRC
Lots of possibilities here--I'd see if you are getting voltage to coil when you crank as a start as could be as simple as ignition switch.
start
Won't crank, Won't start. revor Misc. Chit-Chat 4 September 16th, 2010 08:48 PM
D-90 stuck in Park, Won't start. HELP!!! brianosaurus Defender Technical Discussions 9 December 12th, 2007 08:45 AM
D90 won't start! rover4x4 Defender Technical Discussions 32 June 13th, 2005 07:42 AM
Rats! Now my D90 won't start. No power to fuel pump jcasteel Defender Technical Discussions 8 March 15th, 2005 08:42 AM
D90 won't start dameek Defender Technical Discussions 1 November 11th, 2004 08:00 PM
» Defender Registry
TIT
SaltyDog
110
Mes788
Add your Defender
