Won't cold start - Defender Source
Old January 5th, 2016, 05:34 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
Won't cold start
I'm outside at work. Defender 90 1994 cranks very strong after fuel relay and fuel pump sound comes on but after that it only cranks and sputters but won't turn over. Thoughts?
Tried repeatedly and also with gas pedal down a bit but nothing. Car is near half full with gas but sounds as if it is fuel starved.
Old January 5th, 2016, 05:52 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
spark???
Old January 5th, 2016, 05:55 PM
wmatos1001's Avatar
wmatos1001
William
Originally Posted by d90boy View Post
spark???
Yes I do have spark. Thanks.
Old January 5th, 2016, 06:26 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Wet weather out? Long time since new plugs & wires? If you have an auto parts or maybe a hardware store handy, dielectric grease in the spark plug boots might be your fix...
Old January 5th, 2016, 06:32 PM
spark???
I didn't think your account allowed you to participate in the Defender Technical Discussions section.
Old January 5th, 2016, 06:34 PM
Do you have carb cleaner? May be worth a shot to remove and clean (spray) the IACV behind the plenum.
Old January 5th, 2016, 08:20 PM
wmatos1001's Avatar
wmatos1001
William
Not wet but EXTREMELY cold. Was 7 degrees this morning and when I left to start it to come home was about 20 degrees. Spark plugs, plug wiring/distributor all new within past 12-14 months.
------ Follow up post added January 5th, 2016 08:20 PM ------
Huh?
------ Follow up post added January 5th, 2016 08:24 PM ------
I don't have carb cleaner on me but I just got home so will bring some to work tomorrow when I'm back at the office with my other vehicle. I did just recently (past 2 months) change the IACV out for a new one (non OEM). Replacing it appeared to have solved a long standing intermittent issue I was having with raw fuel being dumped into the Cats which always occurred following a very high idle. But that is another story and looks to be consistently solved with the IACV.
Back to your suggestion. When you say spray it I assume you mean take it out (unscrew the IACV) and spray into where it goes into the plenum? Or do you mean spray the innards of the IACV itself?
Old January 5th, 2016, 08:28 PM
Spray the IACV piece that is in your hand after you unscrew it.
Old January 5th, 2016, 08:30 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Long shot but I had a Chevy truck that did this one winter.
Filled up my gas tank and the next day the truck wouldn't start.
Ended up getting it towed to the shop, shop drained the tank and the next morning half of my gasoline was frozen... Aka half the tank of gas I bought was water. Might dump some dry gas in there and/or top it off with some fresh fuel and see if she'll start
Old January 5th, 2016, 08:31 PM
wmatos1001's Avatar
wmatos1001
William
Okay great thank you. I will do that tomorrow when I'm back at the vehicle. Appreciate the responses from everyone. I can't help but feel this extreme cold we had today contributed to this but I guess that doesn't explain why it started up so well this morning (although it was in my non heated garage this morning but today sat out for about 9 hours in real cold weather).
Thanks again - Will
P.S. I should have added from the beginning of the thread that when it cranks strong but doesn't run the appropriate dash lights go on, including check engine light, for the duration they normally do (and then check engine goes out) all as if it is a normal start. So I am thinking this is not an ECU related issue. Not sure if that line of thinking is correct but that is my limited knowledge perspective.
Old January 5th, 2016, 08:44 PM
wmatos1001's Avatar
wmatos1001
William
You know you might be on to something with that as well. I hadn't put dry gas in (but usually do) for many months. Thank you won't hurt to pick some up in the morning and dump it in (gas and dry gas).
Old January 6th, 2016, 08:54 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
First really cold morning this winter?
Check your coolant temp sensor (the one that goes to the ECU).
Old January 6th, 2016, 10:30 AM
wmatos1001's Avatar
wmatos1001
William
UPDATE: I came to work this morning armed with a few things based on your feedback but first tried to start the car again and it started a little rough but did start and ran fine. I kept it running for abut 30 mins and put in some dry gas.
Could have been any of the things suggested here but really felt like it was starved of fuel as if there may have been a freeze in the line.
It warmed up overnight and is much warmer today. Gong to be around 40.
Will
Old January 6th, 2016, 10:52 AM
redline_r
Ridwan
1986/Land Rover 110
Does "dry gas" work for diesels as well?
--Trying to sort out a similar no-reason for not starting issue.
Old January 6th, 2016, 10:59 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Maybe Power Service Red/911 bottle?
Diesel 9•1•1 | Power Service
Old January 6th, 2016, 11:00 AM
wmatos1001's Avatar
wmatos1001
William
I'm not sure I have no experience with diesel.
Old January 6th, 2016, 11:39 AM
Similar thing suffered here for months until weather warmed up. Haven't had a chance to get out in it for a couple of weeks. Hopefully its not happeneing again.
My next stop is to question the actual capacity of the battery. Its a cheapo generic job. Wondering if its undersized in cold weather.
Old January 6th, 2016, 11:56 AM
Water in a diesel is bad juju. Very bad for injectors etc. If you remove the drain from your filter and see any water you need a new filter @ a min. I typically have to change filter 2-3 times in order to clear a bad tank of fuel through.
Old January 6th, 2016, 12:29 PM
cowboy
steven
You posted that you changed out the plugs, wires, & "distributor" a year ago & that the new IACV was non-oem...
By "distributor", I would assume that you either meant "cap & rotor" or that the cap & rotor were changed out at that time? If so, was the new cap & rotor also non-oem?
Old January 6th, 2016, 01:15 PM
IACV has absolutely zero to do with the truck starting and idling. What it does is open and close depending on whether the truck is accelerating or decelerating to add bypass air to the engine so that it doesn't stall on decel.
The only reason for a no start when it cranks and you have spark is no fuel. I'd wager that you had enough moisture in the fuel system to stopper the fuel flow when it froze.
start
No start in cold cgalpin Series Technical Discussions 2 January 22nd, 2013 07:53 PM
D90 cold start problems aquamanaquaman Defender Technical Discussions 3 November 25th, 2012 05:03 PM
Won't crank, Won't start. revor Misc. Chit-Chat 4 September 16th, 2010 09:48 PM
Rough Idle @ Cold Start Grover Defender Technical Discussions 7 May 23rd, 2008 08:24 PM
Cold start problem flippedrover Defender Technical Discussions 3 February 13th, 2008 06:52 PM
