won,t start - Defender Source
Old April 6th, 2006, 12:47 PM
jonny wrench
david young
1995 d-90
Exclamation won,t start
my 95 d90 just turned 60,000 miles.so i did all the oils and a new cap and rotor.the old rotor was VERY hard to come off.during my attempt to get it off the shaft came up and was stopped the black cover that says DO NOT REMOVE.i got the rotor off and shaft was rusty.i installed my new rotor and cap but now it won,t start.any ideas would be great.thanks
Old April 6th, 2006, 01:21 PM
Are you getting spark? Sounds like you may have messed the timming up. Does it sound like it is trying to start or does it just endlessly crank? Did you put the rotor back in the same spot you pulled it out at? (pointing the same way?)
Old April 6th, 2006, 04:22 PM
jonny wrench
david young
1995 d-90
yes i put the rotor in the same spot.it doesn 't even try to start.do you know how deep the shaft should sit in the distributer housing?thanks
Old April 7th, 2006, 09:41 AM
Not sure how deep it goes, but are you getting spark?
start
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
Ignition Relocation = No Start...Help JRowe Defender Technical Discussions 5 March 8th, 2004 12:45 PM
