wolf wheel questions - Defender Source
Old June 14th, 2011, 11:48 PM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
i am going to run some wolf wheels on my trailer - i need to get adapters to go from the 5x4.75 to the 5x6.5 lug pattern but there are a couple other questions the adapter place needs
are the wolf wheels hub centric or lug centric?
what is the stud size?
and where do you get lug nuts for these?
are these the nuts?
http://www.rimmerbros.co.uk/Item--i-RRD500010
thanks
Jay
Old June 15th, 2011, 12:01 AM
gchinsr's Avatar
gchinsr
Greg Chin Sr
1996 Discovery 5 Speed
The studs are the FRC7577 60mm painfully expensive now. Most just use the std stud
Old June 15th, 2011, 12:06 AM
bjf's Avatar
bjf
barry f
94 ST #395
You can get the lug nuts at EE
Old June 15th, 2011, 12:08 AM
jjstahl3's Avatar
jjstahl3
Jay S
96 D1 TReK
here is a screen shot of the adapter site - I can order the stud size but not sure which one and the hub centric or wheel centric
Old June 15th, 2011, 07:39 AM
TS888's Avatar
TS888
Tony Sims
1984 110
For a trailer you don't really need hub centered. LR steel wheels are arguably hub centered, but it's a pretty loose tolerance.
Tony
1984 110 "Smokey" (sold)
wheel
need 1 wolf wheel Uncle Douglas Wanted 13 May 5th, 2011 06:55 PM
One Wolf wheel ... Retrofit Wanted 0 April 4th, 2010 12:09 AM
UK land rover steering wheel mpodgorski For Sale - Parts 2 February 1st, 2006 09:56 PM
wolf wheel crobinson Wanted 2 December 30th, 2005 11:19 AM
