Wolf rear axle - Defender Source
Old January 15th, 2014, 05:43 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Wolf rear axle
Can one fit a wolf rear axle to a normal 110 without modifications?
Old January 15th, 2014, 07:08 PM
isn't a wolf axle a disc braked salisbury ?
Old January 15th, 2014, 07:29 PM
Sounds right.
Old January 15th, 2014, 08:01 PM
the rover shop
shayne young
If its drum to disc brake you need to change the whole braking system with newer master cyl , proportioning valve etc etc. make sure the gearing is the same.. 3:54 if I recall... Just did this conversion recently, but I changed to the later front ventilated discs too.. Took all the stuff off a Canadian UK army defender.. Did it all on the side of the road..literally..
Old January 15th, 2014, 10:54 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
Here's what I found on the web ...
-"A real Wolf rear axle has welded on gussets from the axle tube down to the bottom of the diff pan so it looks like a very shallow angle "V" if you look along the underneath of the vehicle, not like a normal diff just hanging down in one place."
But are they interchangeable with a civilian 110?
Pics of HD rear axle vs stock axle? josh-man Defender Technical Discussions 22 July 4th, 2017 04:22 AM
1987 LHD 90 2.5td broadstone For Sale - Vehicles 4 May 21st, 2013 07:27 PM
Wolf Fab RRC Rear Bumper and Tire Carrier Wolf Fabrication For Sale - Parts 12 December 11th, 2012 05:05 PM
$200,000 blr 130!!!!!!!!!! rijosho The Flea Market 39 July 25th, 2012 09:58 PM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
