wolf lab cross bars - Defender Source
Old September 1st, 2010, 02:45 PM
bennett's Avatar
bennett
Bennett
'97 Defender 90 Soft Top #1140
wolf lab cross bars
Im about to order cross bars from jonathan so i can use them with ski racks. He said it wouldn't be a problem to make them a bit taller to give more clearance for the skis. has anyone done this? How much taller do they need to be? Im concerned about the bindings on my board needing to be taken off every time i put the board on the truck
Old September 1st, 2010, 06:01 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I wouldn't think you'd have that issue with the bindings on your board if you fold them up. What are you going to use to attach the boards tothe cross bars? I think Yakima and Thule make a snowboard mount that actually attaches the boards on an angle, not just flat.
I know that make an adaptor for the ski clamps to angle those a bit. I've used those to give snowbaords enough clearance on one side.
Old September 1st, 2010, 08:17 PM
bennett's Avatar
bennett
Bennett
really good thought Alexandra, but am hoping to use a wider setup to carry more gear (usually travel with 4 boards and 2 sets of skis). I think ill need about 6 inches clearance above the top. I may just get the diagonals and call it a day, though.
Old September 2nd, 2010, 01:31 AM
jack SF
jack baran
95 ST yellow
hi. i just got some made by wolf. i have a 95 ST. im in san francisco, you can stop by and check em out. my 5"tall i believe.
Old September 2nd, 2010, 05:12 PM
bennett's Avatar
bennett
Bennett
thanks Jack. PM'd you
any Load (cross) Bars only for the 90? rlynch356 Defender Technical Discussions 6 September 3rd, 2009 12:46 AM
Thule Cross Bars mount Bozman Wanted 9 August 11th, 2008 02:16 PM
Urban Offroad External Cross Bars and Clamps Grover Defender Technical Discussions 4 June 7th, 2008 10:40 PM
Mantec Cross Bars thewap Defender Technical Discussions 0 May 9th, 2006 10:17 PM
Clamps for roll cage cross bars Ntajeep Wanted 1 June 20th, 2005 01:58 PM
