Wolf air intake: how to mount? - Defender Source
Old May 25th, 2013, 11:27 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
OK, am going to attach a Wolf air intake onto the side of my wing. But while there are seven holes to put something through on it, am not sure how this is done on a real Wolf. Are there rivnuts on the wing? I can't see that it would just be screwed on with self-tappers. Any advice would be welcome. Any REMEs out there or anyone own a Wolf that can have a look for me?
Cheers,
Old May 25th, 2013, 11:56 PM
Talleyrand's Avatar
Talleyrand
Cheers,
This is what mean ...
ID:	73123   Click image for larger version
Old May 26th, 2013, 08:00 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Personally I would use M5 aluminium rivnuts. If possible find m5 aluminium fasteners to go with them. I'd also put a ring of self-adhesive closed cell foam tape on the surface facing the wing panel so that you don't have to over-tighten things and to prevent any rattles that might result.
Old May 29th, 2013, 10:23 PM
Talleyrand's Avatar
Talleyrand
Hey Andrew, nice to hear from you! I might be up in Ottawa with the 110 this summer again. Thanks for this, I too figured rivnuts would be the way to go. Where would you order them from?
Cheers,
Old May 29th, 2013, 10:27 PM
ajh
Andrew J. Hutton
Well; if you feel like coming up we can fit it at the same time. I get mine through a local supplier; but down there you should be able to order direct from McMaster-Carr (who won't take new Canadian customers). The Alu ones fit really easily and for low-torque applications they're great; just remember to use anti-seize every time you fit a fastener to them.
Old May 30th, 2013, 03:37 PM
PaulMc's Avatar
PaulMc
Paul McConnell
1989 110 2.5 Turbo-Diesel
M5 RivNuts -
Name:	Wolf Air Intakes.jpg
Fullsize - http://img.photobucket.com/albums/v6...AirIntakes.jpg
Paul.
1989 Arles Blue 2.5TD 110 Hardtop
1999 Epsom Green Discovery II 4.0 V8i 'XS'
Old May 31st, 2013, 03:39 PM
Talleyrand's Avatar
Talleyrand
Fantastic, thanks guys. Diagram is great. Andrew, thanks for the offer, knowing me it'll still be lying around by the time we go to Ottawa so I will probably take you up on that!
Cheers,
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
Air Intake Cover wardnb Wanted 1 August 5th, 2005 08:53 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
Anybody know where to find the Wolf air duct inlets? Hans Misc. Chit-Chat 10 August 24th, 2004 08:24 PM
Wing top Air Intake or Scoop??? adibitar Defender Technical Discussions 7 July 8th, 2004 08:57 AM
