Wobbly tire on a Mantec - Defender Source
Old June 19th, 2012, 08:02 PM
wilyliang's Avatar
wilyliang
Peter
'95 D90 SW #441
Just installed my Mantec rear tire carrier and my spare is wobbling even when the lug nuts are tightened all the way to the bottom of the thread on the post. Anyone encountered this before? I've got a Freestyle wheel, 265/75/16 bfg's.
Figured I could cut some pipe to put behind the wheel, but I'm surprised this thing wasn't designed to work with this wheel already...
Old June 19th, 2012, 08:28 PM
Mine was fine ... I can't recall if it has washers at the base of the thread ...
Old June 19th, 2012, 09:20 PM
The Mantec does NOT come with the threaded washers...I used my old ones from my tire carrier and threaded them on. I initially didn't put them on and the spare was wobbling like you described.
Old June 19th, 2012, 11:56 PM
wilyliang's Avatar
wilyliang
Peter
'95 D90 SW #441
The threaded washer sounds like the right solution. Never had any on the previous door-mounted carrier though. Any idea where to find a set of three?
Old June 20th, 2012, 12:16 AM
Not off the top of my head, BUT I'm sure it's in the parts catalog (http://www.landroverweb.com/Pdf-file..._Catalogue.pdf) and if you can find the proper # here check AB/RN/RDS or if no go there then LRSeries.com or Paddock Spares.
Old June 20th, 2012, 02:52 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
OR get an M16 tap and cut some threads into some round bar, then chop off 3 pieces, about 5mm thick (that's what my Mantec has got on it, and a normal steel wheel nut behind these pieces, the wheel stays on nicely then)
mantec, tire
spare tire wobbly aosias Defender Technical Discussions 5 June 13th, 2010 12:50 AM
Mantec tire carrier vs. TD5 style rear door for 33" tire? motap Defender Technical Discussions 8 January 30th, 2010 09:54 AM
Mantec Swing-Away Tire Carrier david_jackson Defender Technical Discussions 16 December 17th, 2004 05:24 PM
Mantec Tire carrier Installation Questions Eric Siepmann Defender Technical Discussions 6 November 21st, 2004 01:42 PM
Cheapest MAntec Tire Carrier Nobrega Defender Technical Discussions 5 June 29th, 2004 03:21 PM
