Wobbly fuel gauge fix - Defender Source
Old July 7th, 2014, 11:30 AM
richord
Richard Ordowich
1987/D90
My fuel gauge would wobble all over the place. I checked the wiring and although the connectors were dirty, cleaning them did nothing to improve the wobble.
I bought a new fuel gauge sender and that fixed the problem. Easy fix, took about 10 minutes.
Old July 7th, 2014, 12:41 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
It's a much more involved and expensive venture in a NAS Defender 90. Even then, I'm not sure replacing the sender would fix the issue/problem in a NAS.
Old July 7th, 2014, 04:04 PM
It's a feature ... It's a tilt gauge and fuel level.
fuel
Wobbly tire on a Mantec wilyliang Defender Technical Discussions 5 June 20th, 2012 02:52 AM
spare tire wobbly aosias Defender Technical Discussions 5 June 13th, 2010 12:50 AM
Fuel pump and fuel gauge relationship question - troubleshoting... arbik Defender Technical Discussions 1 September 19th, 2006 02:31 PM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
need wobbly brake pedal advice. januconn92 Defender Technical Discussions 6 May 24th, 2004 04:13 PM
