Wobble over 40 mph - Defender Source
Old October 28th, 2009, 07:46 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Wobble over 40 mph
Just got new tires, new QT drag link/HD track rod/connectors. The truck needed an alignment bad AND gave me a death swerve (both directions back and forth) over 40 mph. Got the 4-wheel alignment done today, but still have the swerve over 40 mph. Not pretty. I put on the drag link and track rod. Steering damper replaced a couple months ago.
Any idea what this might be? Worn bushing somewhere? Drag link need some turning? Note that it drove fine before tires/DL/TR swap.
-Ren Ching
Old October 28th, 2009, 07:51 PM
bjf's Avatar
bjf
barry f
94 ST #395
I had it with my new tires over 50. The tires needed to be rebalanced.
Old October 28th, 2009, 07:57 PM
Panhard rod bushings, rear ball joint, ball wheel bearing, unbalanced tire etc.
Old October 28th, 2009, 08:00 PM
smob's Avatar
smob
Steve
True, I'll check those other (non-tire) things tomorrow - but before the installations, I had no problems. Would installing a crossrod eye, drag link, etc etc make something else worse? Or just make it more apparent?
-Ren Ching
Old October 29th, 2009, 04:34 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Does it swerve under braking or all by itself?
I'd check all the suspension bushes and bolts for wear and tightness.
I had a death swerve once associated with the rear radius arms falling off. The M20 nuts had slackened off and allowed a considerable amount of read axle steer
Mike Hammond
Old October 29th, 2009, 09:50 AM
I would check your the nuts on the front control arms and rear trailing arms. I had the same problem, and the nuts were to blame.
Old October 29th, 2009, 10:07 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Steve,
is it worse under acceleration or when coasting? check the easy things first, are all suspension & steering bolts up to torque, are the wheel nuts loose?
check the tyre pressure & balance, one other thing to consider is the swivel housing bearing in the hubs, they should have equal amount of tension on them to mantain a true run on the tyre.
if one has play then the result will cause the steering to wobble and possibly lead to the need to keep correcting the steering, it would have to be quite bad to do this and i would have thought you'd have felt it before unless your TRE's were sized.
to check preload remove the TRE's from both hubs and turn the tyrel lock to lock they should be equal, check with a spring balance and wheels removed for accuracy.
landys may be bad for the pocket & the planet but are fantastic for keeping the brain exercised.
have fun
Gren
Old October 29th, 2009, 01:29 PM
smob's Avatar
smob
Steve
Originally Posted by Gren_T
Hi Steve,
have fun
Gren
It occurs during acceleration, coasting and braking over 40 MPH. Less than 40, it's great. I checked the DL, TR, panhard bar/nuts/bushing/connectors. All solid. Messed with the front control and rear trailing arms, all solid. I was thinking that it's the spring bushings, front or rear wheel bearings, or tires. But recently had the springs and shocks replaced, so it's probably not that. Also had the front wheel bearings redone within the last 90 days. Probably not that. Will check the rear later today.
So either something failed in between the tires and DL/TR installation, or the tires are unbalanced. Maybe I just need to jack it up and see if a tire is loose. Weirder things have happened.
Thanks for all the feedback.
-Ren Ching
Old October 31st, 2009, 11:06 AM
smob's Avatar
smob
Steve
Originally Posted by JSBriggs
Swivel ball preload.
Everything else has a multiplying effect on the wobble, but swivel ball preload is usually the cause.
-Jeff
So, I figured it out - the Equipe HD track rod was scraping up against the inside of the Safarigard TR guard (installed by PO). I adjusted the position of the guard so that the TR was centered and tightened the bolts. And it drove perfectly over 40 MPH. It was user install error, but hey, I know about 5x more about steering issues than I did before. Don't ask why I have both an HD rod and guard. Thanks to all those who gave me advice.
-Ren Ching
New Gears and WOW, 10 mph? mdmccallum Defender Technical Discussions 26 December 1st, 2011 03:50 PM
Non D90 tech question... Wobble while braking. jabber Defender Technical Discussions 5 August 30th, 2005 09:22 PM
mph magazine popeohana Misc. Chit-Chat 1 March 16th, 2005 05:44 AM
vibration around 20 mph Rick Carlisle Defender Technical Discussions 19 August 25th, 2004 07:41 PM
Front End Wobble RyanS Defender Technical Discussions 7 April 13th, 2004 05:21 PM
