wobble mystery - Page 2 - Defender Source
Old October 2nd, 2007, 12:12 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Originally Posted by epninety
I'd not put that description onto what I know as DW. Are you sure your CVs are good? What about the phos. bronze bush in the drive flange. I was discussing that causing odd 'wobble' symptoms with the current owner of my old Disco the other day (which now has 200k+ on it).
I don't think it is "deth wobble" either... but something different.
I'm going to try to set the preload tighter see if that helps. Thanks for the info.
I would not think that CV's would manifest like this, last time I looked they were fine. not clicking, tight, etc. they did seem to get a sheen of heat related coloring at some point... what else is there to check?
Could you elaborate on the bronze bushing thing?
Cheers
Old October 2nd, 2007, 02:30 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
I did some changing on my RRC and it developed a slight wobble at 50-55, went away at 60.
Upon close inspection I discovered that the rubber bushings on my shocks were not in good contact with the lower mounting point. They had worn over the years since installation and this was allowing the tires to bounce against the spring without dampening for the first quarter inch or so. With 265/75/16s this was enough to translate to wobble in the steering wheel.
Worth a look since you have covered all the other bases.
Old October 2nd, 2007, 07:10 PM
D90user's Avatar
D90user
steve
Scott- you must have ESP... I was just thinking of this one to my self...while at work...not working. Thanks you for confirming that it is a possibility, I'm going to snug it all tonight... I can only hope it is simple.
Cheers
Old October 3rd, 2007, 05:59 AM
epninety's Avatar
epninety
Dave Haynes
Ibex 240 2.8TGV
Speculation on my part, but the CV runs in a bronze bushing in the stub axle (what idiot said drive flange ?). FTC4319 or later type appears to have a bearing as well.
If that were worn or bust, it might allow the CV to run eccentric when cornering, as it supports the CV ?
Non D90 tech question... Wobble while braking. jabber Defender Technical Discussions 5 August 30th, 2005 09:22 PM
Death wobble saga kellymoe Misc. Chit-Chat 4 February 12th, 2005 05:12 PM
Defender in Paris, and Mystery Guest Doug Misc. Chit-Chat 20 June 18th, 2004 01:52 PM
Front End Wobble RyanS Defender Technical Discussions 7 April 13th, 2004 05:21 PM
That mystery box by the gas tank. wicks Misc. Chit-Chat 7 April 2nd, 2004 07:43 PM
