Wiring to unused/spare fuses - Defender Source
Old January 20th, 2005, 08:00 PM
Trevor Tarr's Avatar
Trevor Tarr
Trevor Tarr
1997 D-90 4.6 NAS ST
I'm adding some new circuits and would like to make use of my D-90's "spare" fuseholders. Is there an easy way to access the backside of the fuse panel, short of disassembling the whole dash? Any tips?
Thanks in advance!
Old January 20th, 2005, 09:12 PM
Add an extra fuse panel under your seat in the battery box. Painless wiring makes all sorts of panels for just this occurance.
Old January 21st, 2005, 07:59 AM
It just comes off with a few screws. My 95 doesnt have a console, but the fuse panel is attached with 2 screws to a plate attached to the bulkhead with 2 screws. There isnt a lot of extra play in the wiring harness , but if you can get the metal plate free, then you should be able to twist and access the back of the fuse panel.
Here's a not-so-great pic of the area stripped down. You can see there is one screw on each side that will release the panel (green arrows). Of course there is some stuff covering up these screws, but I think you'll find it no-so-hard to get to.
Name:	Fuse Panel.jpg
Old January 21st, 2005, 05:27 PM
Trevor Tarr
Trevor Tarr
Jim, great, thanks! I'll take another look at my '97 panel. Hopefully the "some stuff" won't be too hard to get out of the way. I just seem to remember something in my service manual about removing most of the dashboard just to access the backside of the fuse panel....
spare, wiring
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Some wiring Diagrams Mike Hippert Defender Technical Discussions 5 March 9th, 2005 11:14 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Aux Light Wiring Frustratio ronward Defender Technical Discussions 4 August 23rd, 2004 06:53 AM
