Wiring Questions - Defender Source
Old March 30th, 2012, 06:37 PM
usadventureracing's Avatar
usadventureracing
Brett
110
Wiring Questions
Ok I have the engine harness hooked up, but was trying to confirm the other wiring.
The picture with the wiring on the fender I assume is for the headlights, blinkers and fog lights.
The picture of the firewall is the engine harness which is already hooked up and the big one on the left is for the rear light harness (I think), but does anyone know what the small end with the red wiring and there are 2 small single connectors behind the large.
Please correct me if I am incorrect on any of my statements.....thank you
1983 ROW D110
1970 Series III (Parting out)
Old March 30th, 2012, 06:42 PM
usadventureracing
Brett
110
Pictures
Pictures
ID:	49672   Click image for larger version
1983 ROW D110
Old March 30th, 2012, 10:27 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You should have a connector for both front fenders, one will go left and the other right. The headlight circuit usually uses blue wires. You should also have an engine harness, a rear chassis harness which may have more than one plug. On the plug in question what are the wire colors, Green with a white tracer for instance?
Land Rover 110
Old March 31st, 2012, 05:43 PM
usadventureracing
Brett
110
Thank you for the info. I found the other wire harness for the front left side and figured out the signal lights and small white lights.
Now I need to figure out the rear lights and hazards.
1983 ROW D110
wiring
Wiring questions for split charge system aclarke Defender Technical Discussions 5 April 23rd, 2007 04:39 PM
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Stereo Wiring Questions gtg067i Defender Technical Discussions 1 June 19th, 2005 08:10 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
