Wiring Question???? - Defender Source
Old August 8th, 2011, 07:36 PM
Verner Berry's Avatar
Verner Berry
Verner Berry
97 D90
Wiring Question????
97 NAS D90
Every time I connect my trailer I blow the 5amp running lights fuse. However, it only blows when I crank the truck, if I only turn the lights on without turning the truck over the amp will not blow. Additionally, all blinkers on the trailer function correctly with truck running or not.
Could this be a ground issue?
Any thoughts would help.
Thanks, VB
Old August 8th, 2011, 08:27 PM
carlosz's Avatar
carlosz
Carlos
apparently you are crating resistance, yes more than likely it is a floating ground, lack thereof or improperly grounded harness, at trailer or trucks pig tail...
all I can suggest is double check all parts of your connections.
Old August 8th, 2011, 08:36 PM
Verner Berry
Verner Berry
97 D90
Thanks for the info. I love wiring issues!
wiring
Trailer wiring question.. DonFromWhitby Defender Technical Discussions 23 June 30th, 2013 10:37 AM
NAS AC wiring question or call it a random wire question bjf Defender Technical Discussions 7 May 5th, 2009 09:58 AM
Custom wiring question Doug Defender Technical Discussions 7 December 15th, 2004 02:43 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Winch wiring question flippedrover Defender Technical Discussions 4 January 11th, 2004 09:20 PM
