Wiring Question - 12v Fuel Pump - Defender Source
Old February 9th, 2016, 09:15 PM
I am looking to install a sedimenter (from Robert Davis) and 12V fuel pump (Mr Gasket 12D Electric Diesel Fuel Pump from eBay) with my dad, who bloodied his knuckles as a diesel mechanic for the US Marines in Vietnam. In other words, he is the brains and at this point, I’m just the brawn. We’'re stuck on the wiring and could use some help. We have a 1986 ROW 110, with a 200Tdi.
We realize that the pump wiring from a 12V relay is:
86 : ignition circuit - white (+) when key is on
85 : ground (-)
30 : Positive (+) from battery (usually taken off main starter lead)
87 : (+) when key is on
Sadly, I don’'t yet know enough to show my dad where these wires actually are (or are coming from), or where to put the 12v relay, etc. As expected, he doesn’'t want to monkey up the truck, and while he knows diesels, he doesn’'t know rovers. I have searched, but cannot seem to find anything –that makes sense. Mostly, this is because though I'm comfortable with the mechanics of these trucks (with dad's help), the electrical side of the equation has always been my nemesis. Wiring diagrams are like hieroglyphics to me - my eyes glaze over and I don't know what I'm looking at (though I am trying to edumacate myself as much as possible).
Basically, we’re staring at the wires from the 12v pump in one hand, a 12v relay in the other, and the truck in my driveway, and can’t get it figured out just yet. So, what is the best way/place to get a positive wire and an ignition wire, and the best way to add a fuse to that line?
Lastly, any tips on the which fuel line, clamps or other nozzles to use would be most helpful.
Thanks - brian
Old February 10th, 2016, 09:15 AM
Up for help from the morning crowd
Old February 10th, 2016, 09:30 AM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
I'm interested in this also. I have one laying around from Davis as well, never got around to digging into it and figuring it out on my own
Old February 10th, 2016, 09:58 AM
BlackField's Avatar
BlackField
Oscar
D110
Well, once you get behind the dash you should easily be able to see the cluster of white wires (literally 4-5 white wires joined together). Failing that you can go to the ignition switch and follow the white lead from there.
As far as your + for your 30 pin it can be as simple as wiring it from the battery with an inline fuse. Other locations for Live + are the brown wire at starter, ignition switch or light switch.
Old February 10th, 2016, 10:25 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I haven't got around to installing mine yet either. Just another ignorant unfortunately.
Old February 10th, 2016, 10:29 AM
Send me a PM and I will try to walk you thru this. It's not difficult. If you need me to I can make you the wires.
Old February 10th, 2016, 10:47 AM
LRover's Avatar
LRover
J. Michael McCaig
This is how I did it: Fuel pump black wire goes to ground, red wire goes to relay terminal 87. Relay terminal 85 goes to ground and 86 can be any fused power source that comes on with the key. I took mine off of the fuse block. I mounted the relay on the bulkhead in the engine compartment and power to terminal 30 came off of the main power lead from the starter with an inline fuse near the source. I hope this helps.
Old February 10th, 2016, 10:55 AM
If you are not planning a whole raft of aftermarket wiring installs....then I would use a waterproof relay and mount it in the battery box with a simple waterproof inline fuse holder. the rest is pretty straightforward.
OTRATTW :: Accessories :: Relays
OTRATTW :: Accessories :: Fuse Holders and Fuses :: Bussmann MINI Fuseholder-HHL
Old February 10th, 2016, 11:07 AM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Also you don't need the 12v pump, to mount the sedimenter Robert sells. I have two, one on my 95 classic 300 tdi, and one on my 94 NAS defender 300 tdi. Neither uses a fuel pump.
Old February 10th, 2016, 11:46 AM
Raub - put this on your schedule for your next trip up. We can do them both at the same time
------ Follow up post added February 10th, 2016 11:47 AM ------
Bill - many, many thanks. PM inbound.
------ Follow up post added February 10th, 2016 11:50 AM ------
Oscar, Michael, John, Mark - thank you for the replies. Very helpful and the process is getting clearer.
Said before, and will say again - this community is cool.
fuel pump wiring bypass ember Defender Technical Discussions 6 October 18th, 2012 08:21 AM
1997 D-90 fuel pump wiring diagram Tyler Wirken Defender Technical Discussions 3 October 3rd, 2012 01:44 AM
Wiring Fuel Pump to a seperate switch, Good or bad idea? Neil McCauley Defender Technical Discussions 4 September 3rd, 2010 05:20 PM
Fuel pump and fuel gauge relationship question - troubleshoting... arbik Defender Technical Discussions 1 September 19th, 2006 02:31 PM
Fuel Pump, Switch, Relay, or Wiring? bbandit Defender Technical Discussions 19 July 10th, 2005 12:08 PM
