wiring new coil help? - Defender Source
Old April 19th, 2005, 12:19 AM
mattdh's Avatar
mattdh
Matt Hurst
need help wiring the ignition coil-i have four small wires.first wire is in an oversized black sleeve-i think it goes to the ballast resistor? can some one let me know if im right or not? also if i goes to the ballast and my new coil has the ballast built into it where do i wire this? the other three wires are white,one is a small white wire, one is a large white wire and one is a small white wire with a black stripe-i am guessing these go to the positve and negitve post come off the coil?can some one tell me which go to where? that all for the coil wires i have another small white wire by the air flow senesor plug that i need help with also-the air flow sensor plug and this small white wire with black rings around it, in an oversized black sleeve, come off the same wire loom-i have no idea where this wire goes to?anybody have any idea of what im talking about
Old April 19th, 2005, 07:54 AM
I have to wire mine today also, if no one replies I'll fill ya in with what I do.
Old April 19th, 2005, 08:13 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
The wire with the sleeve goes to the tach, I believe. The white and white with black stripe go to the ignition coil and the other white is the switched ignition 12v. I do not think there are any ballast resistors in line in these trucks.
coil, wiring
COIL (ignition) questrion rover4x4 Defender Technical Discussions 6 September 7th, 2010 08:00 AM
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Performance Ignition Coil solihul Defender Technical Discussions 1 May 27th, 2005 04:28 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
