Wiring issues- similar to heath - Defender Source
Old September 1st, 2007, 09:24 AM
vesparover's Avatar
vesparover
brian bertolini
Hi everyone, I'm having a similar problem to heath. I have an hei distributor that keeps blowing the module. I had noticed that the trailor light on the dash- the green light that typically flashes when you turn on your turn signal, is staying on. If I replace the module the truck will run untill i turn it off, sometimes I can get several start and stops out of it. But ultimately it blows the module in the dizzy. Anyone have a correlation to that light staying on and it's effect on the ignition? Any help would be much appreciated.
Brian Bertolini
wiring
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Getting Help, Outstanding, & Known Issues chrisvonc Support & Suggestions 0 May 23rd, 2004 06:00 PM
Front speaker wiring issues Hans Defender Technical Discussions 4 February 13th, 2004 11:38 PM
