Wiring Issue - Defender Source
Old December 16th, 2015, 01:26 PM
jperakis
James Perakis
94 ST
Wiring Issue
Guys,
I had a Matador worklight installed where the 3rd brake light is supposed to sit. It had been wired to the reverse light.
Yesterday, took it off and installed a hella brake light (wired now obviously to the brakes).
Some strange things started happening afterwards
My dome light no longer works. It used to turn on when the doors were opened and when you flipped the switch to "on". Now, the 'on' switch doesn't work and nothing happens when the door is opened. To make it a little more strange, if I flip the switch that powers my compressor for my ARB lockers, the light turns on very dimly. Same is true if I hit the headlight/turn signal switch and pull it towards me (opposite of high beams).
So not only is my dome light just acting weird, but my compressor won't turn on now (it just dimly lights the dome light, but nothing else).
getting in and out of the truck last night was interest as it was so Fing dark!
Any thoughts, comments of otherwise?
I'm assuming something happened when rewiring the 3rd brake light, but i have no idea where to begin on this one.
remember two things...
Old December 16th, 2015, 01:34 PM
How did you connect it? From which side did of the vehicle did you connect it? Does the 3rd brake light work? The brake lights and indicators share quite a few bedfellows throughout the truck.
Old December 16th, 2015, 01:37 PM
If one thing turns on another, it is ground issue. One item is powering the other through a shared ground.
Old December 16th, 2015, 01:53 PM
jperakis
James Perakis
94 ST
connected via the right side
------ Follow up post added December 16th, 2015 10:54 AM ------
Interesting.
I'll check it out the ground later today. really pissed that I f'ed this up!
thanks for the quick feedback
wiring
97 D90 fuel relay/wiring issue roverrees Defender Technical Discussions 5 December 10th, 2014 09:57 PM
Fuse Box/Wiring Issue waveridin1959 Defender Technical Discussions 7 April 12th, 2013 04:27 PM
Wiring Issue... Help Please isleofbones Defender Technical Discussions 5 February 9th, 2013 07:00 PM
wiring issue - lights ORover Defender Technical Discussions 9 February 4th, 2010 11:13 PM
Private Messaging "Read Reciept" issue? chrisvonc Support & Suggestions 0 May 23rd, 2004 08:51 AM
