Wiring/Ignition Problem - Defender Source
Old May 30th, 2004, 03:25 AM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
Question Wiring/Ignition Problem
Hey Guys,
A buddy of mine recently purchased a 95 ST and for some reason the former owner had some kind of safety device installed on his truck where it will only start if the turn signal is on (left). The truck also idles and revs as the turn signal is clicking. Has anyone heard of such a bizarre thing? How should/could it be remedied? Is it an alternator issue?
Old May 30th, 2004, 12:37 PM
They must have put a relay in line with the ignition system, as you have found out it's not the best idea as it adds more wire length into the hole thing and this causes the ignition system to pick up noise and do odd things when the left turn signal is on. I would look at the left turn signal wiring and try to find where it ties into the ignition system. I think they may have put it under the DS wing or by the fuse box, but those are just guesses.
Old June 1st, 2004, 05:45 PM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
Thanks Mike...I will check it out
wiring
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Air Locker problem sflash868 Defender Technical Discussions 1 May 9th, 2005 09:40 AM
Ignition Problem Dfndr90 Defender Technical Discussions 1 November 21st, 2004 08:26 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
