wiring help... windscreen harness - Defender Source
Old December 29th, 2015, 10:15 AM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
I'm working on installing the wiring harness for my heated windscreen. It's for a RRC but using a Defender harness from Mobile Centre. Nice looking harness... too bad I have to modify to fit. I'm stuck with not knowing where one wire should go from the switch. It's the negative side of the light. Does it just get grounded?
It's a switch out of a 94 RRC. The switch wires go to terminals 1 & 4 on the timer relay and the light goes to 87 on the 70A relay and that's where I'm stuck with the one other wire off the light.
Old December 29th, 2015, 02:04 PM
I did that install last summer, IIRC, one wire does just go to ground. You've got your switch illumination taken care of already? Mine was a Defender install, so I just poached an identical lead from a nearby unused switch. 130s don't need any rear wipers or defrost etc, so I think it was one from there.
Old December 29th, 2015, 02:27 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Thanks Jim. The RRC has common illumination for the aux switch panel which I have to sort out while I'm in there (hopefully just needs new bulbs). The heated windscreen & rear screen each incorporate a warning light in each switch.
Really hoped to get this in before the first snow but we got that this morning.
wiring
Need help tonight- windscreen install (Stafford VA) Matt_110 Misc. Chit-Chat 5 July 30th, 2014 11:22 PM
Part Number Help - Windscreen Rubber Plug Wolf Fabrication Defender Technical Discussions 3 February 9th, 2012 08:06 PM
94 D90 wire harness & 94 A/C wire harness mdmuf Wanted 1 August 24th, 2007 09:33 AM
Heated Windscreen Wiring TDI Guy Defender Technical Discussions 4 August 30th, 2005 12:00 PM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
