Wiring Help - Defender Source
Old May 26th, 2012, 01:04 PM
dlane's Avatar
dlane
David Lane
1997 AA Yellow #1147
Wiring Help
I am looking to start adding accessories needed to my 97'. First, I need to get an extra lighter plug put in toward the back seats for an ARB fridge. And after a while, a compressor for lockers, winch, lights, etc... Any good, safe, and clean way to add in those circuits?
Old May 26th, 2012, 02:05 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Easiest would be to start a new circuit at the fuse box under the bonnet. There are some empty small fuse receptacles located there to feed your outlets. Easier to wire into than the interior fuse box plus it bypasses the hot/cold issues associated with the ignition key system.
Old May 26th, 2012, 02:07 PM
look at the battery box recondition threads
Old May 26th, 2012, 10:49 PM
Heres a good thread, I stole a bit of his ideas:
http://www.defendersource.com/forum/...ad.php?t=34813
Old May 26th, 2012, 10:53 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
http://www.defendersource.com/forum/...ad.php?t=26830
I've since added a rubber hood to the threaded post terminal and I've added a second Blue Sea box that's switched (by relay) from the ignition circuit.
Old May 27th, 2012, 02:26 PM
dlane's Avatar
dlane
David Lane
Thanks Guys! I am going to run over to West Marine to see what they have in stock. if not, I am going to buy the stuff from Amazon. i almost thought about buying the stuff from Painless wiring, but that stuff is ridiculously expensive!
Old May 27th, 2012, 02:49 PM
FYI I got most of my actual wire from http://www.waytekwire.com/products/ based on Ed/sonoros recommendation. DON'T buy the wire off Amazon...most is just glorified speaker wire. You GXL-ish type primary wire at least for this stuff.
But I did get my breakers/blue sea fuse boxes/etc off Amazon.
Old May 27th, 2012, 04:14 PM
One more thing...I ran a blue sea aux 12v outlet in back as well (http://www.amazon.com/Blue-Sea-1011-...8149435&sr=8-1) and went with pretty heavy gauge wire (maybe 10 or 8 if I recall), I'd suggest you do the same if you're running a fridge/etc off of it.
I'd also suggest adding breakers before the blue sea fuse boxes, I went with a 120amp Bussmann breaker (http://www.amazon.com/Bussmann-Hi-Am...sr=1-1-catcorr) before each of my fuse boxes. I also likewise did one fuse box always hot and one fuse box is ignition activated.
I thought I had a pic of the final product, couldn't find it but here's one that's close to done:
Old May 28th, 2012, 02:09 AM
dlane's Avatar
dlane
David Lane
Jason, where did you mount it at. Trying to avoid having to cut into anything. I hate doing that.
Thanks!
Dave
Old May 28th, 2012, 08:42 AM
I'm 100% with you on not cutting/changing things, though I sort of made a minor exception with the rear 12v. I cut a 1.5" hole in the removable interior lamp wiring cover that is all the way in the rear on the driverside. That's where I mounted the 12v accessory plug as I thought it made the most sense, and being it was just one hole I figured I could always get a replacement removable panel of I wanted to bring it back to "stock".
Old May 28th, 2012, 09:25 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
West Marine across 470 has the blue sea stuff in stock, they also have some nice 12v outlets
Old May 28th, 2012, 03:34 PM
Just keep in mind that - and I'm speaking as someone who owns a boat - there is like an 8000% markup as soon as you walk into west marine. If it costs you $8 at WalMart, it will be like $640 at West Marine for the same thing .
Old May 29th, 2012, 07:56 PM
dlane's Avatar
dlane
David Lane
West Marine: $56
Amazon: $48 + Free Shipping + No Tax
wiring
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Some wiring Diagrams Mike Hippert Defender Technical Discussions 5 March 9th, 2005 11:14 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Aux Light Wiring Frustratio ronward Defender Technical Discussions 4 August 23rd, 2004 06:53 AM
