wiring help - Defender Source
Old March 2nd, 2009, 11:13 AM
dbj836
Brad Jones
wiring help
I have looked through the FAQ and did a search and have not found the answer to my question.
I am replacing the factory radio with an aftermarket and am using a MUD center dash consule and need to splice into the factory power plug for the radio.
I have found the info for 93-95 wiring but not for my 97 - I know there are issues with the factory amp and will not touch that.
I just need to know which is the ignition hot, always hot and the illumination wire.
Thanks in advance.
Old March 2nd, 2009, 03:55 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
According to the '97 wiring schematics it should be:
Illum - RB - Fuse 11 (Pin 6 at radio, Pin 2 at the fuse box)
12v - P - Fuse 2 (Pin 4 at radio, Pin 4 at the fuse box)
Ign - WK - Fuse 5 (Pin 7 at radio, Pin 10 at the fuse box)
wiring
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Some wiring Diagrams Mike Hippert Defender Technical Discussions 5 March 9th, 2005 11:14 PM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Aux Light Wiring Frustratio ronward Defender Technical Discussions 4 August 23rd, 2004 06:53 AM
