Wiring harness Wht the heck are these - Defender Source
Old November 29th, 2012, 12:12 AM
CDeWan
Clay DeWan
5.3L beastie
O.k. I think I know the answer to this one but wanted to confirm. Anyway, I bought a 95 wiring harness a few years ago from a forum member. I am trying to wrap up the wiring in the cab and came across these two plugs. Since the harness is in a soft top, I have not seen the plugs before compared to my 94 which leads me to believe that the harness is from a station wagon and these plugs are for the rear defroster and rear wiper. Could someone confirm?
Thank you,
Clay
Old November 29th, 2012, 07:58 AM
Thank you,
Clay
Could also be AC
Old November 29th, 2012, 08:17 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The wiring harness for the rear screen should be at the bulkhead engine side. Your picture shows them at the center console so I would imagine they would be for heated seats, door locks or like. What are the wire colors? If the black plug has a solid yellow wire that may make sense, (door locks, Overdrive, gear selector to start) The red plug with a brown wire should be a hot lead with the black wire as a ground.
Land Rover 110
Old December 4th, 2012, 04:46 PM
CDeWan
Clay DeWan
5.3L beastie
wiring
mike,
I will check the colors.
Can someone confirm that their are typically 3 switches on the SW between the dash and the dash vent - 1 Rear Window Defrost, 2 Rear window wiper and 3 rear window washer? Or am I missing something?
Old December 4th, 2012, 04:58 PM
Check my diagrams half way down the first page and see if they help you.
http://www.defendersource.com/forum/...ad.php?t=40075
Old December 5th, 2012, 06:50 PM
aosias's Avatar
aosias
Alexandra
1995 D90
IIRC for the AC blower. Should be a tab on the bulkhead in the footwell area that it connects with when not in use.
ht, wiring
Wiring Harness - Possibly Burned CDeWan Wanted 7 September 27th, 2009 07:35 PM
hella wiring harness rover4x4 Defender Technical Discussions 19 March 6th, 2006 08:29 AM
Stereo Wiring Harness Manufacturer? priest944 Defender Technical Discussions 7 January 11th, 2005 06:03 PM
90 main wiring harness & TDI engine mounts TDI Guy For Sale - Parts 5 December 13th, 2004 01:45 PM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
