Wiring Harness too long...splice or bundle? - Defender Source
Old June 17th, 2010, 02:45 PM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
I finally installed the lights on my truck (4 Hella 4000s on the roll cage and 2 500s on the bumper.) and there is a bit of slack in places on the wiring harness. These are places where I can not just "trim the end".
Thoughts on my options:
1 - Bundle and zip-tie the extra
2 - Crimp the two together (bullet connectors or just a crimp connector)
3 - Solder the two together and heat-shrik
Dave
Old June 17th, 2010, 03:17 PM
You don't' say how much slack but I say bundle and zip tie. No need to introduce failure points imo.
Old June 17th, 2010, 03:45 PM
matansas
jon lyons
97 AA Convertible
wiring roll cage
how did you resolve getting the wires from the roll cage into the truck
Old June 17th, 2010, 03:49 PM
BTW, since it's wire, you should be able to work the slack to places where you can conveniently hide it.
Old June 17th, 2010, 04:51 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
Up to 2 ft on a couple...it is all under the drivers fender...so there is tons of room.
------ Follow up post added June 17th, 2010 03:56 PM ------
Used a black wire loom down the back side and then into a perfectly sized gap in the hood..can't even tell it is there.
I had previously ran a remote + terminal to the drivers fender area, so everything is nice and tidy there now....
The wires for the switch go through the main bung into behind the instrument cluster.
wiring
hella wiring harness rover4x4 Defender Technical Discussions 19 March 6th, 2006 08:29 AM
Stereo Wiring Harness Manufacturer? priest944 Defender Technical Discussions 7 January 11th, 2005 06:03 PM
90 main wiring harness & TDI engine mounts TDI Guy For Sale - Parts 5 December 13th, 2004 01:45 PM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
