Wiring Harness Question - Defender Source
Old September 13th, 2015, 01:15 AM
RhinoRover's Avatar
RhinoRover
Andy
1986 D110
I am in the process of sorting the wiring for my 4.2L conversion in my '86 110. I salvaged the complete wiring harness from a 1994 RRC LWB and have just started to disassemble it. This may be a long shot, but does anyone know what type of connection this is? There looks to be quite a few of these connections throughout the harness. It is located close to a snap connection that ultimately should lead me to the starter relay that I need to remove and keep, but I can't without first separating the connection that's pictured. Small black wires look like grounding wires to me. What do you think?
Old September 16th, 2015, 08:57 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If it is a solid black wire it is just a splice for a series of grounds. LR did this type of thing in the harnesses. You will find them on other wires too. I have seen some that have a type of goo inside the tape and others that have a crimp connector. Pretty common.
wiring
Question about 300tdi wiring harness... J. Pound Smaller Projects 2 October 23rd, 2014 12:22 PM
90 trailer wiring harness question (UK 7-pin adapter?) nathanwind Defender Technical Discussions 11 November 25th, 2012 07:42 AM
94 D90 wire harness & 94 A/C wire harness mdmuf Wanted 1 August 24th, 2007 09:33 AM
ARB wiring harness question KevinNY Defender Technical Discussions 2 January 21st, 2007 11:33 AM
Trailer Wiring Harness Weldon Defender Technical Discussions 17 August 26th, 2004 12:03 PM
