wiring for trailer lights - Defender Source
Old August 15th, 2012, 10:22 AM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
I am going to be doing the wiring for trailer lights. Does anyone have any thoughts/suggestions/diagrams on where and how to tie in to do it right? I appreciate the help. thanks
Old August 15th, 2012, 11:19 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Have you done a search in this forum ??
There's been plenty of discussion on this topic before.
Old August 15th, 2012, 09:43 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
You may have a multi plug for the trailer wiring by the rear cross member RHS. It should be a grey connector with a orange inside. If you do not have that then you can get the wires from the rear connection at the sides by the rear door or gate. If you have speakers behind the grill box. Since you have yellow and red rear lights you will have to have a converter to work correctly with the solid color trailer lights.
Land Rover 110
Old August 20th, 2012, 11:08 PM
graves14
Tyler Graves
1997 D-90
On my 97 I ended up cutting off the OEM plug and splicing in a standard circular deal with an extension down to the receiver area. Then bought a converter to the standard 4 pin for most light trailers (walmart, pretty inexpensive).
The OEM Rover plug was really expensive to find the right mate.
ht, lights, wiring
wiring issue - lights ORover Defender Technical Discussions 9 February 4th, 2010 11:13 PM
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
» Defender Registry
Truck
zqqz
Billy
Highseas
Add your Defender
