Wiring: Disconnecting/Reconnecting (Replacing Switches) - Defender Source
Old August 15th, 2010, 05:29 PM
District 90's Avatar
District 90
BENJAMIN/LEE
1994/DEFENDER 90
Question Wiring: Disconnecting/Reconnecting (Replacing Switches)
I'm currently replacing both the wash/wiper switch & the indicator switch. Removed the steering column housing & the steering wheel.
What is the best technique for disconnecting & reconnecting the rubber wiring pin connectors?
Old August 15th, 2010, 05:45 PM
pull them apart .... I find holding them between thumb and wrapping my fore finger around one side and doing the same on the other allows be to 'wiggle' them a bit ... after a while they pull apart!
Old August 15th, 2010, 07:36 PM
District 90
BENJAMIN/LEE
1994/DEFENDER 90
I did that for a little while. I should wiggle it a little more. Thought there may be a specific technique: holding it with the thumb on the left corner while yin yang it on the other connector. Tanks
Old August 15th, 2010, 10:49 PM
specific technique on defenders is whatever works! ;-)
Old August 18th, 2010, 12:45 AM
District 90
BENJAMIN/LEE
1994/DEFENDER 90
Cool wire pin housing disconnected & reconnected
The connectors were easier to connect than they were to disconnect. I was told that's a good sign of a healthy connection: good contact & prevents moisture.
They do take some wiggling; it gave me a blister on my forefinger (though it completely dried up, without popping it, because my body dehydrated from the blistering summer heat today My body needed all the water it can get!). 2 plier wrenches were needed. They were the original switches from '94. A good neighbor who works on his own cars helped me that one. Thanks to the both of you, & for your advice, leastonce. Cheers.
Old August 18th, 2010, 01:03 AM
Next time pack them with dielectric grease when you reassemble.
Old August 18th, 2010, 01:24 AM
District 90
BENJAMIN/LEE
1994/DEFENDER 90
Thumbs up
Gotcha. Thanks for the advice. The '94-'95 indicator & wash/wiper switches are the same. The '97's were using Discovery parts. Always a good idea to hold onto the original housing for the best fit. Make sure your pins are carefully in place when removing & replacing the switches.
ac, disco, switch, wiring
Hella FF 1000's with wiring kit NIB Jammer 48 For Sale - Parts 0 August 15th, 2005 07:40 AM
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Aux Light Wiring Frustratio ronward Defender Technical Discussions 4 August 23rd, 2004 06:53 AM
