Wiring couplings for hella lamps? - Defender Source
Old October 12th, 2005, 02:14 AM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Arrow Wiring couplings for hella lamps?
Anyone know where I can buy some couplings that I can use to make all my lights quick-disconnect? I need to get a couple that are for single lights (connect two wires) and one that will do 8 for the row up top.
(stumped)
Old October 12th, 2005, 08:11 AM
Hmm, I know you can get the single light ones at Autozone for relitively cheap and they are outdoor automotive grade so they are good in the rain. For the top the first thing that comes to mind would be to use a trailer connector of somesort. You can always combine all the grounds into one pin as long as it is rated for the current.
Old October 12th, 2005, 08:37 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
(stumped)
You can purchase the Hella Wire Harness that comes with the quick disconnects (2 of them). I have a few in stock, let me check the price and see what your D90Source discount would be. I'll get back to you later today.
John C.
Old October 12th, 2005, 10:23 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
last I checked, NAPA sells the GM weatherpack connectors of various sizes individually.
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old October 13th, 2005, 02:23 AM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Thumbs up
(stumped)
Wicks
This is what I used to bring all of my electrical components together (http://www.connex-electronics.com/ht...e/pp_main.html). Some assembly required, but you can color code each lead so that you may identify which one belongs to a specific device. If you'd like I can post some pictures of my set up. Currently my Hella 4K's, rear work lamp, cigar lighter, aux. 12V supply, GPS, CB, and soon my Ham are all routed through a single quick disconnect. Of course this is after they run through a fuse and/or relay. I did the same for the hot leads for all of the above as well.
Let me know if you need some pictures. The pics on the website above don't really provide scale.
Regards
DJ
Old October 13th, 2005, 06:57 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
linky no worky
Jimmy Buffett
Old October 13th, 2005, 07:45 AM
Link works now DJ let me know if thats the right thing.
Old October 15th, 2005, 12:29 AM
bjenk
Brian Jenkinson
1994 D90
I used the GM connectors. I purchased them locally at On Track. It is a race car shop. I think that the connectors are a little pricey for what you get, but they seem to be very good. I made it so I could remove my front ARB without removing the hella's. WHY? I don't know, but I do not want to look back and wish I had!
Old October 15th, 2005, 01:31 AM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
yep! thanks Mike.
lamp, wiring
A/C wiring in 95 jcasteel Defender Technical Discussions 1 August 14th, 2005 06:53 PM
In dash wiring? oldscratchggf Defender Technical Discussions 6 July 14th, 2005 11:26 AM
Wiring question - bypassing ECU for rear defogger dmarchand Defender Technical Discussions 8 September 30th, 2004 11:21 AM
Aux Light Wiring Frustratio ronward Defender Technical Discussions 4 August 23rd, 2004 06:53 AM
