Wires cut under right seat, what s there? - Defender Source
Old March 19th, 2016, 06:59 AM
Itox
ANTONIO
1996
Hi,
I've just bought a defender which was property of police department in Croatia, and which they've taken away a few parts, I've bought the car with engine, reductor and gearbox in parts, and with cut off wires under the right seat.
Can you please guide me in to what parts I need to get to bring the car back to life?
- I need help with those electrical parts mostly under the seat, the engine and the rest I'll first take out and try to reassemble on the table and then Ill know more, but there s a pic of it too.
thanks a lot in advance!!!!
pix:
Old March 19th, 2016, 07:17 AM
rovertrader's Avatar
rovertrader
Dale
I have only seen a few Pumas, but I think the uncut plugs are for a series of relays, and the cut group of wires was the ECU. Not even 75% sure, but close I think.
You will likely be better served on a UK based site, as the Puma availability here is nil.
Good luck with it, and welcome to the disease!
Old March 20th, 2016, 08:58 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
yep looks like a Td5 set up. They cut the ECU wires and the fuse box is missing.
Land Rover 110
ht
Is there a right and wrong way to lubricate the wheel hubs? Zooraya Defender Technical Discussions 30 July 1st, 2013 06:36 PM
Should there be wires going to this? MAX711 Defender Technical Discussions 6 March 8th, 2012 03:57 PM
Is there a fuse for the right side running lights? ADK46er Defender Technical Discussions 5 January 10th, 2012 03:18 PM
300 tdi wanted is there anything out there? Boathead Wanted 3 January 17th, 2011 07:56 PM
