wipers won't turn off - Defender Source
Old November 18th, 2013, 04:11 PM
aosias's Avatar
aosias
Alexandra
1995 D90
1995 D90 ST. Wipers won't turn off. I can adjust the speed but that is it. Pulled the fuse and the wipers stopped. Thought it was the white park switch thing, replace that. No change.
Next idea?
Also, tach doesn't work and AC unit isn't working- no fan. Previous owner says that wiper issued started when it was loaded on the truck and the AC worked as it should. I don't think these are all related but just in case.
Alex
Old November 20th, 2013, 08:15 PM
hamiamham
mike
97 D-90
Not a lot of help but I have the same issue with my wipers when the interior is wet.
Old November 24th, 2013, 09:22 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Wiper switches go bad so it might just be the switch. The tach should just have the lead and light wire going to it. The A/C shouldn't be on either electrical circuit, but....
Old January 12th, 2014, 08:06 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Pulled the intermittent relay on the wipers and they will now shut off. I can adjust them between hi and low. No intermittent setting of course.
Assuming I need a new relay but wanted to check before I order one.
Old June 8th, 2015, 02:10 PM
BlackField's Avatar
BlackField
Oscar
D110
Same problem. Anyone find another solution or other trouble shooting tips?
Old June 8th, 2015, 04:13 PM
BlackField's Avatar
BlackField
Oscar
D110
I got it to stop.
little washers under the park ramp:
Giant washer under the lock ring:
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Windscreen wipers TDI Guy Defender Technical Discussions 22 December 2nd, 2004 12:41 PM
Turn signal--problem solved Davis Defender Technical Discussions 0 July 18th, 2004 08:13 PM
Windshield wipers not functioning properly cdnpaul Defender Technical Discussions 1 November 10th, 2003 02:52 PM
