Wipers - Defender Source
Old April 21st, 2016, 07:31 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Wipers
Any similar experiences or know what's going on here?
NAS wiper arms in intermittent mode moving very slow, almost not making it back to starting position. Working at normal speed however in non-intermittent mode.
Searched for similar issue but didn't find anything on point. Please forward a link if you are aware of prior posts.
Old April 21st, 2016, 07:42 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Failing park switch?
Search function blows....
Rent my
Old April 21st, 2016, 07:50 AM
1of40's Avatar
1of40
1of40
Failing park switch? Search function blows.... .
Thanks, found this nice piece.
http://www.defendersource.com/forum/...ent-14243.html
Old April 21st, 2016, 08:11 AM
Search was improved just yesterday ... It's a lot better. Or it would be better if people could spell ...
Old September 30th, 2016, 10:52 AM
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
Hi everyone,
My wipers stop where they should but i have another issue,
My wipers don't seam to go up until close to the end of the windscreen and they leave quite a bit of screen without wiping, about 4 inches (11cm).
anyone has an idea of this?.
Lately i installed two new arms, spindles and the endless screw.
Any ideas?
Thank you,
Sent from my HTC_M910x using Tapatalk
Old October 2nd, 2016, 09:23 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Clay ..if they are moving slow at first but pick up with water on the windshield, less resistance and with speed, on high, you might just have sticky wheel boxes. Be careful in what grease you use as it needs to be the less resistance type. My guess is that they are just funked up and need to be cleaned. The wheel boxes could be warn however and need replacement.
Land Rover 110
Old October 2nd, 2016, 12:08 PM
olsin77's Avatar
olsin77
Olsin Petro
1999/Defender 110
Hi,
They are new also.
And they have same speed while moving. But of course when is raining and they are worked a little bit they move better, still they don't go far in up position.
wipers? mattdh Defender Technical Discussions 19 June 4th, 2013 12:57 PM
wipers overrun artm Defender Technical Discussions 18 February 26th, 2009 01:32 AM
Any 3rd party windshield wipers? cdnpaul Defender Technical Discussions 36 April 27th, 2008 09:36 PM
Windscreen wipers TDI Guy Defender Technical Discussions 22 December 2nd, 2004 12:41 PM
Windshield wipers not functioning properly cdnpaul Defender Technical Discussions 1 November 10th, 2003 02:52 PM
» Defender Registry
1304
xjahx
Bandit
DreamRover
Add your Defender
