wiper wash bottle mount - Defender Source
Old January 8th, 2007, 11:33 AM
can someone show me a picture or illustration of the mount that the euro style (if different) windscreen washer bottle goes on in the inner wheel well? I dont' have one, and can't find reference to it to replace or refabricate.
Old January 8th, 2007, 06:24 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Mark,
I'm not sure if my ex mod qualifys as european but I will snap a couple photos for you this evening.
Old January 9th, 2007, 12:56 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Mark,
Here are the photos that I promised. I hope they help.
Name:	Washer Tank 001.jpg
ID:	7827   Click image for larger version
Name:	Washer Tank 002.jpg
Name:	Washer Tank 003.jpg
ID:	7829   Click image for larger version
Name:	Washer Tank 004.jpg
Name:	Washer Tank 005.jpg
Old January 9th, 2007, 10:29 AM
They do. thanks alot for the effort. my connector is completely different. I guess there are two types.
Old January 9th, 2007, 11:01 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
Is your washer bottle built into the wing with just the cap sticking out?
Eric
Old January 9th, 2007, 12:11 PM
no. it sits proud. Just got off the phone with RN. they sell a jumper that goes from the T connector to the special connector on the pump that solves my problem. my washer bottle and pump connector is attached for posterity and future searches.
Old January 9th, 2007, 01:45 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
That's bizarre. On my NAS 110, it's built into the wing and the only thing you can see is the filler cap. Although your setup would be a helluva lot easier to work on (this I know from experience).
Chance
Old January 9th, 2007, 02:42 PM
I bought my NAS 110 as a engine compartment fire salvage, and everything in the engine bay was destroyed, which suited me fine for my diesel conversion from scratch. My engine bay, thanks to pendy, looks like a brand new vehicle. I also like replacing parts with euro defender standard stuff, as it's a hell of a lot easier and cheaper to source parts than the hard to find NAS stuff. I got the washer bottle from huddersfield on ebay.
Old January 9th, 2007, 03:11 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Gotcha. Makes sense to me!
Chance
Old January 14th, 2007, 05:01 PM
On a related note, I ended up getting a non-NAS 110 rear wiper switch from RN (PN# PRC4449), but it's not intuitive on how it should be wired. There are 4 prongs, and the switch is a simple on/off and momentary for the wiper fluid. Does anybody know it should be wired?
Old January 15th, 2007, 11:40 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Got an ohm meter? If you do, just buzz it out. More than likely, one of the four is the supply, one is washer and the other two are wiper speeds
Chance
mount
Td5 Over Flow Bottle and Air Cleaner Mount SafariHP The Vendors Loft 0 January 26th, 2009 07:55 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
Rear spare tire mount - nuts Kimos Wanted 1 December 4th, 2004 08:17 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
