Wiper stepper motor/switch - Defender Source
Old July 5th, 2012, 10:29 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
A few weeks ago I found a thead with the part that I believe I need but I can find the damn thread now. My wipers aren't working so well in the intermittent mode. Isn't this due to a bad switch in the dash? Since I can't find the thread I stuck now and therefore i cant order a replacement. Would someone please help?
Old July 6th, 2012, 07:43 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Was it this one? http://www.defendersource.com/forum/...ad.php?t=14243
Land Rover 110
Old July 6th, 2012, 01:29 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Originally Posted by MC22958 View Post
Bingo. Thx
Old July 6th, 2012, 08:37 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Is this the part :
http://www.roversnorth.com/p-1770-pa...per-motor.aspx
Old July 6th, 2012, 09:23 PM
slowpoke496
Bryan
94
I had no intermittent operation and changed out the park switch and it ended up being the wiper relay. Although when i changed out the wiper park switch i found that the housing was cracked anyway. The other symptom i had was the wiper fluid mode only sprayed fluid it did not actuate the wipers.
Old August 17th, 2012, 12:44 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
I now have the same problem. Replaced the park switch and still the same problems.
Wipers work fine in high and low but in intermittent mode they work but not properly. The relay clicks in but then seems to click out to fast and stops them. It then clicks on powers on again but not long enough. Also wipers will not return to parked position in any mode even with the new park switch in.
Thoughts?
Also any know the part number for the relay?
Tyler
Old August 18th, 2012, 09:01 AM
slowpoke496
Bryan
94
Tyler,
What happens when you try to use the washer fluid? when my relay was bad it would spray fluid but fail to move the wipers.
for my 94 i needed used wiper relay AMR2341.
good luck.
Old August 19th, 2012, 09:42 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
When I use the washers the wipers do come on so you are probably correct it is not the relay. I am thinking ECU problem not timing power to relay long enough therefore not allowing the intermittent wipers to wipe long enough as well as not hitting the park switch properly perhaps.
I also do not have the familiar ding dong that happens when you turn key to start. Wondering if my ECU is jacked.
Old August 19th, 2012, 09:46 PM
it's nothing to do with the ECU ... it deals with running the engine ... nothing to do with the wipers! Its a land rover not a lexus!
Old August 20th, 2012, 11:13 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
According to my wiring diagram the multi-function ECu controls the intermittent wipers both front and rear. The ECU also dims the dome light etc... Not just controls engine.
It shows wires for the intermittent wipers going to ECU then to relay. Something has to tell the relay when to time out I would assume.
Old August 20th, 2012, 12:46 PM
slowpoke496
Bryan
94
Tyler
I am on a mobile device what model and year is your vehicle?
Old August 20th, 2012, 01:31 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
1997 d-90 sw
Thx.
Old August 20th, 2012, 11:08 PM
slowpoke496
Bryan
94
Tyler,
http://www.defendersource.com/forum/...ad.php?t=13792
It appears that the 97 has an aux ecu. the link above describes a possible fix for your issue.
good luck
Old August 21st, 2012, 12:10 AM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Thanks Bryan for all the work. I fixed it tonight! Crazy simple fix. Kinda embarrassing as well. Apparently at some point along the road in my five year revuild I removed the wiper relay as well as the one next to it in the fuse panel. One is a yellow one and one is a green one. Well I put them back in the wrong plugs. So the wiper one was missing an 87a terminal. So a simple flip flop of the relays fixed it. Two second fix after hours of troubleshooting.
At least it was easy.
motor, switch
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
Stepper motor same on RR? waveridin1959 Defender Technical Discussions 15 December 16th, 2004 10:52 AM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
