Wiper slack - Defender Source
Old May 12th, 2007, 04:53 PM
dnp
David
1995 Defender 90
Wiper slack
My windshield wipers have a tremendous amount of slack in the linkage. At rest, I can probably move the wipers in an arc of about 45 degrees before they stop. This translates into an erratic movement when they're on (they probably stop for 1/2 second at the end of the sweep each way.)
Is this characteristic of these vehicles or is there a bushing repair kit or other fix that's available to remove all of the slop in the wiper linkage?
Old May 12th, 2007, 05:59 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
The OEM wipers work great with no slack. Aftermarket wipers tend to be a little sloppy when clicked into place.
Old May 12th, 2007, 06:47 PM
dnp
David
1995 Defender 90
When I read back over my original question, I realized it may not have been very clear. To clarify: the slack I'm experiencing has nothing to do with the wiper blades or the wiper arms. What I'm talking about is the mechanism by which the arms/blades are actually moved. For example, if there is a great deal of slack in the wiper linkage (the parts in between the dash and the windshield frame), movement by the wiper motor will not be directly translated into movement in the wiper arms/blades. My wiper motor works fine, as do the arms and blades. What I believe to be the problem is with the linkage and the corresponding bushings. If that's NOT the problem, I can't figure out why the arms can be moved so easily and the arms stop for a short period of time at the end of each sweep......I'm just wondering if there's a bushing replacement kit that'll tighten everything up...
Thanks.
Old May 12th, 2007, 08:14 PM
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
Ah....okay.
Have you made sure to tighten the allen screw that attaches everything together on the outside of the truck? Sometimes these get loose and rust. They will seem tight to the allen wrench, but are loose.
There is a thread somewhere on here that addresses the loose wiper subject.
http://www.defendersource.com/forum/...referrerid=292
ac
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
front wiper arms- used mattdh For Sale - Parts 5 March 6th, 2006 06:13 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
