Wiper Problem - Defender Source
Old June 19th, 2009, 04:14 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Wiper Problem
The wipers do not work on high... THey work fine on the slow and delay setting though. I'm guessing the switch??
Legend in My Own Mind.
Old June 20th, 2009, 10:45 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Anyone?
Old June 20th, 2009, 10:56 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Easiest way is to carefully pull the wiper switch and use amp/voltmeter(and electrical diagrams) to check out the switch. Switch is expensive, so don't throw it away until your convinced it is the culprit.
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
