Wiper Park issue (only on normal/fast speed) - Defender Source
Old October 23rd, 2009, 12:20 PM
Doing some searches and need a clarification on which part is correct for my issue.
Symptom: the wipers do not park on Normal and Fast speeds, they just stop where ever you turn off the switch.
they DO park on Intermitant setting (return to the bottom as expected)
Wiper relay ?
(The AMR2341 is for the 93 110 or the 94-95 D90.)
or a limit switch issue on the motor?
95' D90 - daily driver..
Old October 24th, 2009, 03:15 AM
crickets? Anyone?
Old October 24th, 2009, 08:09 PM
61rover's Avatar
61rover
John Crouse
Mine works exactly the same way. Either it's supposed to work that way or we have the same problem.
Old October 25th, 2009, 02:29 AM
i think we have the same issue since it did Park the wipers until a few days ago.
Old October 26th, 2009, 10:23 AM
bitz's Avatar
bitz
Jon
NAS D90, 85 D110 CSW, 66 Dormobile
It's most likely the park switch on the motor. The relay doesn't control the park so I'm not sure why it's working the way it is but I would take the park switch off the motor and inspect the plastic rod that controls the switch. It comes off pretty easy, just pry outward a little bit with a small screw driver and then slide it to the left. Once it's off you'll see the platic rod I'm talking about.
Old October 26th, 2009, 11:28 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Sorry don't need any Crickets!
My issue is that at speeds the blades smack the base of the windshield on the right side. If I'm at a light or driving slowly the smacking is reduced? I would take the random stop any day over smacking on the return.
Weldon
Old October 26th, 2009, 11:39 AM
You can adjust the arms. There is a small piece of spring steel that holds the arm on by pressing into an indent otherwise it just basically sits on a splined shaft. If you apply a little pressure straight up off the splined shaft it will slide off. Do it gently so you keep the position. Rotated it one spline clockwise and push back on. Repeat until smacking stops.
hth
charles
Old October 26th, 2009, 02:41 PM
ok thanks - dumb question - does anyone have a picture of the park switch on the motor or where it is generally located - i took apart the dash a bit last night to get a look at the motor but want to be better prepared.
Old October 26th, 2009, 03:01 PM
bitz's Avatar
bitz
Jon
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=220418639515
Old October 28th, 2009, 02:16 AM
That link does not work for me - anyone have another shot of them (or a link)
thanks
Old October 28th, 2009, 09:07 AM
bitz's Avatar
bitz
Jon
http://www.lrseries.com/shop/product...ch=wipe&page=1
wiper motor - park kevorkjan Smaller Projects 6 May 22nd, 2009 11:45 AM
Intermittent wiper issue Craigd Defender Technical Discussions 2 January 8th, 2008 02:53 PM
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
