Wiper Motor Q - Defender Source
Old January 24th, 2008, 01:01 AM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Wiper Motor Q
Did a quick search and didn't immediatly see what I was looking for, got bored of searching, so here it goes.
Whenever I turn on my front windshield wipers it takes a good two to three seconds for them to start up. Once they are going it is like watching the. "Little Train that Could" traveling across the windscreen and I'm expecting them to stop mid-stroke. I mean it's almost painful! The worst part is the laughter from my wife as she is making fun of their anemic performance The wiper blade inserts are not the problem, I think. Is this OEM type performance or should I start worrying?
Old January 24th, 2008, 01:15 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Mine are pretty lively. Does it do the same both in slow and fast? How about intermittant?
May just need the pivot points to be greased, possibly the gearbox on the motor is gummed up, I'd also check the voltage leading to the motor.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 24th, 2008, 09:06 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Andrew,
Mine are the same way and I attribute it to a twenty year old truck. I once read a thread on this but can't recall if it was on this board or another. I will do what I can to keep this thread alive until we solve this.
Old January 24th, 2008, 08:09 PM
Probally something from lack of use. I know when I start mine they act sort of sickly but will get going after a while. Consider how old the wipers are and how much use they have probally had, I know mine have been used but probally a whole lot less than many other 12 year old vehicles on the road...
Old January 24th, 2008, 08:14 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Usually problems like this are caused by either the adapters slipping on the shaft or bad gear boxes/cables. I would try tightening the adapters first. They slide onto the shaft on the outside and the wiper mounts to them. There is a small hex set screw that you need to tighten. Unfortunately they are often seized so this may be more difficult than it sounds. Good luck!
Old January 24th, 2008, 11:03 PM
97D90's Avatar
97D90
Andrew Walcker
1997 Defender 90 LE
Thanks to everyone for the replies! Living in SoCal during drought time is probably pretty hard on the wipers as they are rarely used. I think I've used them more this month than the last three years combined. I'm diving in this weekend and will let you know what I find.
motor
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
Rear Wiper - Anyone Please Kimos Defender Technical Discussions 14 November 8th, 2005 02:10 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
