Wiper Motor HELP - Defender Source
Old June 13th, 2004, 08:40 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Wiper Motor HELP
Does anyone know how to hot wire a wiper motor to check and see if it works? The plug on it has 5 wires...I don't have a clue what ones to jump to a battery to check the motor.
Legend in My Own Mind.
Old June 13th, 2004, 09:36 PM
Larns
George Larner
On the output of the plug there should be three wires coming out, blue, yellow, red. The blue is for the earth and the yellow and red are your low and high speed, the others a for the auto return action so they don't stop in the middle of your windscreen. Try unplugging either of the red or yellow wires and running a jump wire to either of them an something should happen, rember to always run a fuse in your jump wire, otherwise bad karma could result.
Thats the way my 110's wiper motor is set up anyhow.
Good luck
Cheers Larns
motor
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
Rear Wiper - Anyone Please Kimos Defender Technical Discussions 14 November 8th, 2005 02:10 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
