wiper issues (revisited) - Defender Source
Old August 11th, 2010, 07:48 PM
bennett's Avatar
bennett
Bennett
'97 Defender 90 Soft Top #1140
Recently, my wipers have decided to only make a pass or two at a time before stopping in various places in the windshield. If i turn them off and then back on, they usually complete their journey and come to rest in the appropriate place. I've seen lots of posts on the board about wipers not parking correctly and / or the intermittent wipers not working at all, but mine just seem to be lazy. Has anyone else had this happen? I plan to replace the motor and park switch, but before i take the entire dash apart, i thought i would ask.
Old August 12th, 2010, 08:36 AM
Check the point where the wiper arm mounts to the drive arm. Your symptoms sound like the little retaining bolt (retaining allen head) is loose. You may have to first pull the arm to see the little round splined piece that has the retaining bolt. To remove the arm you should be able to lift the arm to remove the pressure on the splines and pull straight off.
hth
charles
Old August 12th, 2010, 09:59 AM
bennett's Avatar
bennett
Bennett
thank you charles, ill try that
Old August 12th, 2010, 10:01 AM
I should have mentioned that to test this, just try move the wiper arm before doing anything else. It should hardly move if ok, but if it is loose you'll know right way.
Old October 16th, 2010, 07:53 PM
bennett's Avatar
bennett
Bennett
finally got around to this. I don't see where the retaining bolt is. I see a hex where the drive arm attaches to the car. THe entire drive arm is a bit loose.
Old October 18th, 2010, 02:34 PM
Here is the piece I am talking about. Hope the picture is clear enough
Old October 18th, 2010, 02:45 PM
bennett's Avatar
bennett
Bennett
Thank you Charles. Ill take a look at it tonight. I realized that the wipers werent parking either, so im replacing the switch, but i might as well replace those pieces while im at it. Where did you get that one?
Old October 18th, 2010, 02:52 PM
I think RN, but any of the parts guys should carry it.
Old October 18th, 2010, 03:33 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
RN has them for about $12 each
http://www.roversnorth.com/store/p-6...iper-arm-.aspx
Old October 21st, 2010, 08:49 PM
discotdi
Todd Miller
Land Rover
RDS has them for $5
Old October 21st, 2010, 09:14 PM
Your problem sounds more like a wiper motor on its way out than a slipping drive flange on the wiper wheel box's.
No need to take the "whole dash apart"
Just the padded wiper cover above your left knee and possibly loosten the instrument pod. Park switch is built into the motor.
Old October 22nd, 2010, 10:53 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Doug, on my 90 the driver side wipes perfectly fine. The passenger side seems weak and unable to do the job when the wiper arm is in place. It sort of slips. I thought it was a bead drive flange at first. I replaced the drive flange and it still "slips" under load, otherwise I can see the flange turn in sync when the arm is off. What do you think I've got here?
Old October 22nd, 2010, 01:13 PM
Clay,
Behind the dash (remove top pad ) are the wheel boxes that are driven by a cable/worm gear. There is a bendable tab in the middle of these box's that you are meant to tweak inward when the gear starts slipping as you indicate. Bending the tab pushes the cable into closer contact with the drive gear. This adjustment is detailed nicely in the factory workshop manuals.
Old November 17th, 2012, 05:58 PM
bennett's Avatar
bennett
Bennett
Bendable tab
Doug or anyone else who might know,
Where is the "bendable tab" you mentioned? I need to tighten up the linkage to my wipers. I have the dash open and can see the internal drive gear for the wipers, but not sure what I need to tighten
Old November 18th, 2012, 02:55 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Thanks for the tip Charles! I just checked and both of mine have substantial play in them. Only problem is my metric allen keys don't seem to fit. Neither 2.5 or 3MM fits. Is it it not metric?
hth
charles
Old November 18th, 2012, 03:13 PM
Mine used to jump about a bit ... I did the tab trick and greased everything but what actually fixed it was opening up the motor and finding a lose washer jammed in the gears.
Old November 18th, 2012, 03:49 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Imperial 3/32 did the trick but they seem to be rusted shut. Might have to drill them out.
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
Speed Sensor and ECU Issues DJ Menasco Defender Technical Discussions 14 February 16th, 2006 08:45 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
