wiper issues - Defender Source
Old April 20th, 2011, 12:43 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
wiper issues
Search did not yield similar issues.
1984 110. Wiper's work at normal speed in high speed position and stop in all other positions. They do not park properly so you have to time it to get them down. The yellow wire is disconnected on the wiper park switch in this mode. When the yellow wire is attached the wipers work on all speeds as advertised; however they park themselves in the full up position. Replaced wiper park switch. Wipers do the exact same thing. I've tried every combination of red, blue, and yellow on the wiper park switch and haven't resolved the issue. One of the combos made the wipers go insanely fast, forget which one, but I forget which one(it was really fun to watch).
Any ideas on what could be the issue?
You little rebel, I like you.
Old April 21st, 2011, 05:48 AM
TS888's Avatar
TS888
Tony Sims
1984 110
99% sure the problem is the round gear that drives the wipers. It sounds like it is installed 180 degrees from where it should be. It has a nylon "hump" on the back that opens the park switch, if it's set the wrong way it parks at the wrong end.
It's an easy fix.
Tony
1984 110 "Smokey" (sold)
Old April 21st, 2011, 01:28 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Sounds like the issue. Thanks. I'll take a look at it tomorrow. This fixed plus a defender 200tdi that will shortly be on the way plus the new coat of pastel green will put the truck back into the running for a keeper.
Old April 30th, 2011, 08:26 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
It's an easy fix.
Explain how it's easy. I can't figure out how to get at it to reset it 180 degrees.
Old April 30th, 2011, 09:38 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Tom posted a pic that shows the RHD and LHD setup in the following thread.
http://www.defendersource.com/forum/...ighlight=wiper
4 screws on the back of the motor and 1 clip on the outside, pull the gear and put it in the proper way if that is the issue.
Old April 30th, 2011, 12:21 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Thanks. I had done the screws then was driven nuts by not getting it out. Set the screws back in it and flipped it over and then saw the clip. Then got frustrated at how long I had fiddled with it and the dog was whining in the back yard so I quit for the time being. Thanks. This does look easy.
Old September 29th, 2016, 02:26 PM
deanclean's Avatar
deanclean
Ryan Stevens
1995 Defender 300tdi
thanks to this post (and many others on other forums) finally figured out my wiper issues. I changed park switch and relay and wipers were still parking in "up" position. I was going crazy trying to figure it out. Took the motor apart twice before I realized what people were describing when saying to remove part of the gear and turn 180 degrees. the wheel and piece I had to change are the same color so it looked like one solid piece. Anyway, got it off and rotated it and had success. Now wipers work as they should. Thanks again!
Old September 29th, 2016, 02:33 PM
Matt_110's Avatar
Matt_110
Matt
110
Damn! I have a brand new wiper motor I installed then removed due to frustration (parking in up position). Since I have my dash apart, I'll try this fix too. Kicking myself for not realizing this...had no idea there was a RHD & LHD version
1987 110, 2.8TGV, ZF Auto
Old September 29th, 2016, 02:35 PM
deanclean's Avatar
deanclean
Ryan Stevens
Definitely worth a try. It never made sense to me that I would have to change that piece on a motor that's been in the defender for 20 years, but maybe previous owner was having same issues.
Old September 29th, 2016, 02:37 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Please take pictures and post. I'm not picturing this in my head.
Mike & Carrie
Defenders draw attention. Don't buy one if you're shy!
Old September 29th, 2016, 02:43 PM
Mike & Carrie
See the linked thread above. http://www.defendersource.com/forum/...fix-30797.html
wiper issues (revisited) bennett Defender Technical Discussions 16 November 18th, 2012 03:49 PM
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
