Wiper intermittent fried? - Defender Source
Old February 10th, 2013, 04:43 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
After the snow, somehow my wipers were on the down(intermittent) setting and froze on the windscreen, they eventually came free but now I have no intermittent setting, but the 2 faster speeds work. Figured its the switch. But would appreciate some input.
It's a 1999 td5 dash set up.
Old February 10th, 2013, 04:56 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
I would say it is the switch as they can go pretty easily. If its the same switch as in the NAS 90 then all it is is a bearing thats sandwich between two plates that have ridges.
Old February 11th, 2013, 02:58 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
So it's the switch and not the motor?
Old March 9th, 2013, 06:23 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Anyone?
Lost the slowest setting on my wipers, is it the motor or the switch?
Old March 9th, 2013, 10:56 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Your motor works fine..
Old March 10th, 2013, 08:05 AM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
Hi, Tom-
I agree with Jeff that your motor should be OK. The switch is really simple, so you can also take a look at the contacts on the back, but it's probably not that either. The intermittent relay is either hosed or the contacts on the relay or socket are corroded or otherwise shorting. I'd try checking and cleaning it up first, or just replace the relay.
For less than $20 on Ebay and elsewhere, you can also swap in a Rover programmable one for $50-60 or a VW/Audi "99" relay that allows you to program/select the timing. I've done it on both of my trucks and it works good. There are also several places on the web that you can stumble on about it if you search "Defender programmable wiper" or a similar search. I also responded to a thread that Doug started a few months ago about it. http://www.defendersource.com/forum/...ad.php?t=41931
Murph
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old March 10th, 2013, 08:19 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Very helpful
Thanks Chris
Intermittent wiper issue Craigd Defender Technical Discussions 2 January 8th, 2008 02:53 PM
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
