wiper doesn't go all the way down when turned off - Defender Source
Old October 16th, 2010, 09:03 AM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
My right wiper doesn't go all the way down when I turn the wipers off. Does anyone know how to tackle this? if possible I would rather not have to get a whole new wiper set up i.e. new motor, etc. because other than this they work fine. thanks for the help.
Old October 16th, 2010, 04:50 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
There is no adjustment in the system except spindle tension and flipping the gear to adjust the rest position from lhd to rhd and vice versa. You might be able to shim the gear wheel or pinion to tighten things up. Myself I just live with them coming to a rest somewhere in the bottom 2" of their stroke, even there they are well out of the way.
Old October 16th, 2010, 05:23 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
You should be able to clock it by pulling the wiper arm off (fold the wiper straight out from the windshield and pull the arm from the splined shaft) and then reinstall with the arm in the desired position.
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
Wiper Motor HELP TDI Guy Defender Technical Discussions 1 June 13th, 2004 09:36 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
