Wiper Delay--programmable. Malfunctioning. - Defender Source
Old June 16th, 2016, 12:22 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I have a bosch programmable wiper relay but I can't get it, or other, programmable relays to work! My normal delay relay works, but the programmable clicks like it wants to latch but doesn't. Before I dig into all the wiring, has anyone had this issue before?
Old June 16th, 2016, 12:42 AM
Message JohnsD90. He just did this mod within the last few months.
Old June 16th, 2016, 10:03 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Thanks--I have reached out.
Old June 16th, 2016, 10:41 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Unfortunately I am awaiting the harness from England, so I have not even gotten to point of failure yet!
Old June 16th, 2016, 11:03 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
If the park switch on the gear is stuck, no amount of programming will make it work.
Do your wipers park in the same position or stop where they are when turned off?
RDavisinVA
Old June 17th, 2016, 01:32 AM
marsik's Avatar
marsik
Sergey
1994/90
Originally Posted by rdavisinva View Post
If the park switch on the gear is stuck, no amount of programming will make it work. Do your wipers park in the same position or stop where they are when turned off?
Hi, my wipers stops where they are turned off!
is the any way to fix it and make it park normally?
Old June 17th, 2016, 08:18 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by marsik View Post
Hi, my wipers stops where they are turned off! is the any way to fix it and make it park normally? Thanks
Call Zack at Rovers North for a park switch.
Old June 17th, 2016, 08:45 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
They work normally, including when the regular relay is in. Park normally too.
Old June 17th, 2016, 10:10 AM
marsik's Avatar
marsik
Sergey
1994/90
thank you
Old June 17th, 2016, 10:27 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Yes!
RDavisinVA
Is the Rovers North site malfunctioning? quick968 Defender Technical Discussions 0 November 27th, 2015 11:28 PM
VDO Programmable Speedometer Upgrade Question dsh12 Defender Technical Discussions 1 October 5th, 2012 05:11 PM
1997 Speedo Delay brettm Defender Technical Discussions 3 January 11th, 2012 11:27 AM
EAS Delay Relay AMR1111 o2batsea Wanted 17 May 22nd, 2011 11:57 AM
Wanted: wiper control cdnpaul Wanted 1 February 12th, 2006 05:45 PM
