Winterizing your Defender - Defender Source
Old October 24th, 2012, 09:22 AM
Akitatw4's Avatar
Akitatw4
Tom
1995/D90
Ok guys (first of all I searched the forum before posting and didn't find much), my 1995 D90 is a summer only vehicle for me here in Maine. So I am planning on storing it for the winter. I was wondering if someone would share their process and or experiences in doing this. I have never prepped a vehicle to sit for about 6 months, so even the basics would be appreciated.
Thanks in advance.
Tom
"Be Polite, Be Professional, but have a Plan to Kill Everyone You Meet." - Gen. James Mattis, USMC
1995 NAS D90- Alpine White 'Oink'
Old October 24th, 2012, 09:29 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
Here is what I do:
Change the oil
Add Stabil fuel stabilizer
Try and find non-ethonol gas to fill it up with
run it for a bit to get the stabil through the system
Hook up a battery tender to the batteries
Mine is in a rodent-free zone...you may need to take other precautions if yours is not...
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
Old October 24th, 2012, 09:31 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Thanks in advance.
Tom
Tom, you could send it here for the winter and I'll keep her looking good for you! if thats not an option at a minimum change all of the fluids and turn her over once a month....trickle charge the battery and keep the fuel topped off and add a fuel additive and you're all set. how many miles do you drive it a year?
Old October 24th, 2012, 09:32 AM
1. fill the gas tank and use some gas stabilizer like Stabil. run the engine for a few minutes so that the stabilizer gets into the lines
2. put out some mouse traps as they can do a bit of damage. don't put the mouse traps inside the truck. But put a cardboard box on the floor somewhere. Any mice will use that first.
3. remove the battery and hook it up to a battery tender
4. change the oil in the engine if it is not fresh and run it for 5-10 minutes after the change. Pull the fuel pump fuse and run it until it dies to get the gas out of the lines.
5. use an oil treatment in the engine like Lucas oil treatment (not related to our electronics)
6. You can put your truck up on axle stands to keep the tires off the ground
7. WD40 everything - probably not much value in that but some feel it puts a protective cover on everything.
Old October 24th, 2012, 09:35 AM
Akitatw4's Avatar
Akitatw4
Tom
1995/D90
Bill,
This was my first year having it and I put about 2K on it this summer.
Any suggestions on a good battery Tender?
Tom
Old October 24th, 2012, 09:45 AM
Bill Larson
Bill Larson
Bill,
Tom
I don't use a trickle charger, but I use other products from; http://www.geniuschargers.com/
good products good company!
------ Follow up post added October 24th, 2012 08:46 AM ------
josh today is the day you hit that number!!!!!!
Old October 24th, 2012, 09:51 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
This is the one everyone was missing...
Get a good breathable padded cover (assuming indoor storage)
Old October 24th, 2012, 10:04 AM
GYM's Avatar
GYM
Gary
97 SW
I've heard of putting vehicles on jack stands at the frame to reduce sprung weight on the suspension; but jacking it at the axles does what, prevent flat spots on the tires? On a radial tire, is that really necessary?
Old October 24th, 2012, 10:10 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Lets you store with good air flow, bag the wheels with desiccant to minimize rotor rust, prevents flat spots, and no worries when leaving the car in neutral and parking brake not engaged.
Old October 24th, 2012, 10:23 AM
If you don't put it on jack stands, put more air in your tires. When Land Rover ships vehicles over they have about 60-70 psi in the tires to prevent flat spots.
Old October 24th, 2012, 11:13 AM
I will disagree and say I prefer to remove the battery entirely rather than a tender.
Old October 24th, 2012, 11:18 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I thought this was going to be about driving it in the winter, one of my favorite times to drive my Rovers when I lived in VT. Winterization for my softtop Lightweight was Sorels, long underwear and a heavy jacket. A down parka and AF Arctic survival pants for long trips.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old October 24th, 2012, 11:32 AM
DMSLongLake
Dave Sherwood
1994 D90 ST
This is what I use:
http://batterytender.com/products/au...emisphere.html
I know that on the tender my battery will live a long life...so I would rather be safe than sorry.
Plus I am too lazy to disconnect the 97,000 cables on my two batteries...so I have the battery tender leads hard-wired out a bung in the battery box, so I can plug in without evern removing the seat :-)
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2008 RRS
2013 RRS
Old October 24th, 2012, 11:40 AM
I had a battery tender short out and kill a battery badly so maybe I am jaded.
Old October 24th, 2012, 12:23 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
These can be had for less if you walk into the store & buy one.
http://www.sears.com/diehard-platinu...1&blockType=G1
Old October 24th, 2012, 12:37 PM
6 months isn't really long enough to need to do all that stuff. Fill the tank, change the oil, bring the battery inside. That's 'bout it.
Old October 24th, 2012, 12:54 PM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
Inflating the tires near max pressure definitely helps.
Whichever battery tender you use, be sure it is designed to properly maintain the battery and not just overcharge it.
I Use the glue traps near my stored vehicles for the for the mice...They work great and don't have a food source to overly attract them.
A decent cover helps protect the paint but they can be expensive...I use old bed sheets to cover mine, mainly on the top where dirt and debris settles...
Old October 24th, 2012, 01:04 PM
Bill Larson
Bill Larson
Good idea for the cover, didnt think of that. I've never found a good cover that could handle a rack!
discotdi
Todd Miller
Land Rover
Winterize, ha ha suckers. roll up windows and close sunroof.
Old October 24th, 2012, 01:18 PM
Viggen's Avatar
Viggen
Jarrod
none
Rodents hate moth balls, just an FYI. Throw a couple in the footwells and a couple on top of each tire and youll be fine. My MGA and MGB sat through the winter and mothballs in a few key areas worked wonders.
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 08:14 AM
Whats in my container??????? SafariHP The Vendors Loft 30 November 26th, 2015 07:31 AM
Defender 90 Scoop For Sale - Vehicles 0 December 10th, 2005 11:46 PM
1994 Red Defender 90 for sale BrianConway321 For Sale - Vehicles 5 February 22nd, 2005 09:27 PM
