Winter Storage - Disconnect Batteries or not? - Defender Source
Old November 13th, 2010, 08:46 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
So bought an LR3 and decided to store the 90 for the winter...did some searching and so far and came up with this plan:
1 - Filled the tank
2 - Put in Sta-bil and ran the engine for a while before storing
3 - Bought a Battery Tender 2-bank charger
So my questions are:
1 - Do I need to disconnect the batteries (PITA)
2 - The directions say to not hook the negative to the batteries, do to a ground...is this just legalize and CYA or can I clamp on to the NEG terminal on the battery?
Old November 13th, 2010, 02:03 PM
crobinson
Chris Robinson
97' D1
Yes, for the Battery Tender to work you have to disconnect the ground/negative on the truck battery. You can leave positive connected.
Old November 13th, 2010, 05:45 PM
DMSLongLake
Dave Sherwood
1994 D90 ST
And then I connect the neg to the post?
Old November 13th, 2010, 06:48 PM
crobinson
Chris Robinson
97' D1
Yes, the neg on the Battery Tender goes on the neg battery post. After you have hooked both Battery Tender cables to the truck battery then plug it into the wall outlet.
disco
Overland Experts - winter drving.... dmarchand Trips, Trails and Events 5 October 2nd, 2007 05:02 PM
Defender winter storage Defender13 Defender Technical Discussions 4 October 30th, 2006 02:12 PM
D90 Storage Boxes chrisvonc For Sale - Parts 8 January 27th, 2005 02:19 PM
Lockable Storage in D-90 chach Defender Technical Discussions 16 May 4th, 2004 01:18 PM
Batteries dead jorge Defender Technical Discussions 13 October 28th, 2003 03:28 PM
