winter/salt advice - Defender Source
Old September 23rd, 2009, 11:43 AM
wantone
Rick Thompson
94 ST #1222
winter/salt advice
Hi everyone again, (BTW thanks for the fan advice). I am a D90 newbie and have read pretty much over half this forum. My question is this, my 94 I purchased has some minor rust around the axles etc., frame in good shape etc. I am currently taking a wire brush, then priming and painting the surfaces as best as possible just trying to prevent or slow down decay. I live in Nebraska and will be driving in the salt this winter, I plan on hitting the underside at the car wash frequently. I read lots of threads about the salt etc., really eating the truck up, is this just pretty much dependent upon proper care/maintainence? Or should I avoid it at all costs?
Old September 23rd, 2009, 12:27 PM
Grover's Avatar
Grover
Thumbs up
One of the unique attributes of the Defender it's construction, i.e. it mainly held together with steel fasteners (not a unibody). Typically, most of the rust starts in those areas. Also, the bi-metalic construction leads to corrosion b/t the aluminum panels and the steel structure.
There are two ways to look at this:
1) Avoid salt entirely, buy a daily driver vehicle for the winter/salt season
-or-
2) Rust proof the hell out of it and keep it clean.
If your going for #2, take your time and do it right. Remove all rust/scale down to white metal, prime, use frame paint, and waxoyl. Replace non-load bearing external fasteners with stainless and use nylon washers to isolate SS from the Al.
Where possible, place rubber gaskets b/t the steel and Al. Also, waxoyl the insides of the doors, and where the Al wraps around the steel frame.
The more $$$ option is to galvy everything that's steel, however, galvy steel will rust, it just takes much, much, much longer to happen.
Good luck...
Cheers...
Old September 23rd, 2009, 12:31 PM
Yep, lots of Waxoyl and WD40 will go a long way towards keeping your truck nice (if not a bit greasy) for a long time. You can stave off a lot of problems that way and get to the fasteners and stuff as you have the time.
Old September 23rd, 2009, 12:38 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
How many cans (500ml) waxoyl rust inhibitor/hardwax aerosol is required on the underbody of a D90?
Old September 23rd, 2009, 12:39 PM
wantone
Rick Thompson
94 ST #1222
thanks
thanks so much guys, that is what i thought. i did do the wd-40 to slow things down as i get to them. not in a huge hurry to full on restore everything, just cleaning it up to look better and extend the time before full blown redo.
Old September 23rd, 2009, 12:44 PM
Grover's Avatar
Grover
I used 6 cans of the hard wax on the frame, axles, and underbody and 8 cans of the 120 clear wax on the bulkhead, doors, frame rails, rear and mid crossmember, and inside the front fenders.
The biggest job is the prep. I ruined 6 pair of coveralls doing the job...
BTW, I removed the entire exhuast system, fuel tank plate, and the mid xmember to get optimum coverage. You will be suprised what's lurking where the mid xmember mounts...
Old September 23rd, 2009, 12:50 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Regarding prep can we just go to a carwash and have them clean the underbody. Once dry can we start spraying the underbody with waxoyl hard wax and clear wax? Thanks!
Old September 23rd, 2009, 12:57 PM
Grover's Avatar
Grover
That is the big job. I washed/degreased mine by hand with a series of bristle brushes to clean every nook and crany. Very, very messy...
Like I said, it's all in the prep...
Old September 23rd, 2009, 12:59 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
You really want to steam clean before doing waxoyl. If you really want to protect the truck you are best off paying someone to do the job right. I paid Robison Service good coin to do my d2 and the results were amazing.
Old September 23rd, 2009, 01:00 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Thanks for the information!
How much to have a D90 waxoyled at Robison? Thanks!
Old September 23rd, 2009, 06:30 PM
JJB622
Jimmy Baker
1997 BRG D90
pricing info here: http://www.robisonservice.com/servicedep/waxoyl.asp
Old September 23rd, 2009, 10:02 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
Anyone know where you can get a d90 waxoyled in the Chicago area?
Old September 23rd, 2009, 10:22 PM
Grover's Avatar
Grover
Call RN...I believe there is a facility in Chi that will do the work...I looked into it years ago, but decided to do it myself...
louder horn advice chirider Misc. Chit-Chat 9 April 8th, 2008 04:49 PM
Replacing Alt, H20 pump, fan clutch, and belts - Advice needed arbik Defender Technical Discussions 3 January 7th, 2006 09:11 AM
Advice on buying my first D90 mtbrooks Defender Technical Discussions 7 July 19th, 2005 07:48 PM
Advice Sought... cbass Misc. Chit-Chat 29 March 11th, 2005 07:56 PM
any advice or comments ccrover Misc. Chit-Chat 6 December 7th, 2003 11:43 PM
