Wing top Air Intake or Scoop??? - Defender Source
Old July 7th, 2004, 10:25 AM
adibitar's Avatar
adibitar
Adi Bitar
2001/ TD5 90 Defender
Question Wing top Air Intake or Scoop???
Hello,
I have been wondering about the Wing top air scoop and whether it is a good addition to my D90. All site that I have visited said that they are good for bringing in air for the heater. What I am wondering does it help the engine in really hot weather. Would it help the Air conditioning at all? Maybe my conception of this peice is completely wrong hoping to get some help from anyone.
Old July 7th, 2004, 10:32 AM
Berty's Avatar
Berty
Brett Hurrell
D90 Hardtop 300Tdi
Save your money mate. They're crap. Cosmetic use only.
Sniff my Diff ;)
Old July 7th, 2004, 10:33 AM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
I have the wingtop scoop for the heater and it does help a bit with the heating - gets you more air. But seeing that you're in the middle east, I doubt you need it to help you with the heating at all
Other companies make them for the other side, which is suppose to help with the breathing but I personally have not seen any "realworld" facts or figures.
Glenn
Old July 7th, 2004, 10:37 AM
adibitar's Avatar
adibitar
Adi Bitar
Thanks for your input really appreciate it.
Old July 7th, 2004, 12:05 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
If nothing else it keeps water from collecting inside the fender when it rains.
Old July 7th, 2004, 12:06 PM
Tom Morrison
Tom Morrison
94 NAS 90 (300 TDI)
The Rover's North unit I bought, seems to have solved the problem of snow accumulation causing my heater blower to blow its fuse. Might help with sand as well
I also modified it to house an external GPS antenna.
Tom
Old July 8th, 2004, 05:17 AM
Berty's Avatar
Berty
Brett Hurrell
D90 Hardtop 300Tdi
Hi, Tom
For your situation it would be a benefit as you said. Also the GPS antenna mount is a cool idea.
For improving the heat output, I haven't noticed any difference.
Sniff my Diff ;)
Old July 8th, 2004, 08:57 AM
artm
Arthur Maravelis
97 SW
I had to remove the heater assembly to drain water from the blower motor causing a short. I drilled a few drain holes in the blower housing and removed the plastic squeeze doo-hicky so any water can drain more easily.
The best solution I intend to do is: remove the plastic scoop altogether and clamp some plastic tubing in its place and run it to the rear of the radiator. No more water or snow accumulation problems! You may also get a ram air effect while in motion but who cares.
Heck, if you don't care too much about engine smells you don't even need a tube. Just remove the scoop and cap off the plastic vent - or replace it with a non-vented one.
air intake, wing
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
Wing Top Heater Intake Scoop newfD90 Defender Technical Discussions 2 April 13th, 2006 12:54 PM
Mounting wing top protectors Chaucer Misc. Chit-Chat 5 March 10th, 2004 07:34 AM
Wing top air intakes Peter Defender Technical Discussions 2 October 16th, 2003 10:42 AM
